Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-22-2021, 08:03 PM   #1
pwdcougar
pwdcougar's Avatar
painting over 5 year old epoxy
5 years ago did the bodywork on my Suburban doors and painted them with Nason epoxy primer. For finishing it off all it should need is a coat of 2K primer and some blocking. How should the Nason epoxy be prepped for recoating. It's been 5 years since these were last worked on. I know the 5 year old epoxy has to be sanded or scuffed but with what grit? Also should it get a fresh coat of epoxy before applying the 2K? Lately I've been using SPI epoxy and 2K.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-22-2021, 08:09 PM   #2
mongocanfly
mongocanfly's Avatar
Re: painting over 5 year old epoxy
i had some parts that were done over a yr before with epoxy..i just hit it with 180 and then sprayed the highbuild on...my cabs been in epoxy for over 2yrs..getting ready to hit it as well
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-22-2021, 08:15 PM   #3
pwdcougar
pwdcougar's Avatar
Thanks!
Old 09-23-2021, 08:28 AM   #4
JJH Jimmy
JJH Jimmy's Avatar
I would block the Nason with 180 and then a coat of SPI epoxy. Wait 48 hours and then spray your 2K.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 09-23-2021, 10:43 PM   #5
theastronaut
theastronaut's Avatar
SPI recommends sanding then recoating with epoxy if it's been on there that long.
theastronaut is offline   Reply With Quote
Old 09-25-2021, 04:04 PM   #6
pwdcougar
pwdcougar's Avatar
Thanks Jimmy!
Old 10-04-2021, 04:29 PM   #7
72c20customcamper
72c20customcamper's Avatar
Epoxy has a recoat window . After that time you have to sand no matter what you put on over it.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-04-2021, 05:20 PM   #8
lupo
Sinces your epoxy primer is 5 years old it's possible there may be rust under it
Epoxy primers that use zinc phosphate as an anti-corrosion device are sacrificial. Knock it down with 180, you'll probably go down to bare metal in certain spots, apply at least two coats of your anti-corrosive epoxy and follow it up with your surfacing epoxy and you should be good to go
lupo is offline   Reply With Quote
