![]() Join Date: Aug 2008
info needed on 72 accelerator cable to pedal rod retainer clip
Does anyone have one they would part with? The body shop lost the whole pedal assembly and the one I bought is missing the retainer. I bought one from LM with a bunch of other parts but it is not rright, too small.
I found this one, and it is $6.95 (!), which is bad enough, but to add insult to injury, $11.48 shipping (!) http://www.ss396.com/mm5/merchant.mv...ct_Code=AZC-88 |
Re: info needed on 72 accelerator cable to pedal rod retainer clip
It seems most part strores have an assortment of them.
For the stock 72 pedal assembly the stock cable has the clip (that attachés it to the round hole in the pedal rod) built in. It's the black round plastic thing between the fire wall clip and the little silver bullet. This is the one my 72, I would assume your 72 is the same way?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
