11-10-2013, 08:51 PM | #1 |
Has anyone done a rear disc conversion on an 8-lug?
Id really like to upgrade the rear drums to discs on my C20 while retaining the 8 lug. Has anyone done this successfully? I havent been able to find any conversion kits for the rears, so Im assuming it'll have to be done with factory front parts and a little backyard engineering.
11-10-2013, 09:38 PM | #2 | |
Re: Has anyone done a rear disc conversion on an 8-lug?
11-10-2013, 09:56 PM | #3 | |
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
11-10-2013, 10:04 PM | #4 |
i believ you can use the backing plates and some other hardware off of a 14 bolt ff. but hell if theres a kit available like the one above, go for it! i just found the gold mine thanks chevyland! now i can have 4 wheel discs
11-10-2013, 11:35 PM | #5 |
awesome thanks! Ill check it out
11-11-2013, 01:01 AM | #6 |
Hey guys, they do work with stock rims I did not get the e brake option because when I talked to the guy at blackbirds he asked me if I use my ebrake much, and if I didn't , don't get the ebrake option because it will be more maintenance since it uses another caliper. As far a I am concerned it was my only option since most brake parts are no longer available for the ho72, but also the work it took to do the conversion was no more work than it would have taken to do a brake job even if I could have got the parts. If I remember right he also has an option for flexible hoses that you need to weld a tab on the axle and a piece of flex hose extends to the caliper since it is not right against the axle like the original back of the drums are. If you call the guy a blackbirds he will answer all your questions. It definitely works!
11-11-2013, 01:20 AM | #7 |
425hp409
Texas law requires an operable parking brake to pass the annual safety inspection. Check the laws in your state before you eliminate your parking brake.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
11-11-2013, 07:51 AM | #8 |
If you register your truck as an antique, you don't need the inspection.
Swamp Rat documented his brake install down in the 4x4 build section.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-11-2013, 08:01 AM | #9 | |
Since you are in the Hampton roads area I'd talk with Tim over at Shakerbilt in Chesapeake. He makes disc brake brackets steering and other parts for trucks. Mainly offroad trucks, but the brake kits will cross over. http://www.shakerbuilt.com When ya talk to him, let him know that -j-rod sent ya.
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
11-11-2013, 09:25 AM | #10 |
Will do! Thanks everyone for the info
11-11-2013, 10:26 AM | #11 | |
11-11-2013, 12:17 PM | #12 | |
From my experience working on off road rigs with rear disc conversions... aftermarket rear disc brake brackets typically use 73-87 k10 front calipers. The e-brake calipers they list are more than likely caddillac eldorado calipers with an integraded mechanical ebrake. my 2 pennies. -j-rod
11-11-2013, 12:36 PM | #13 |
I used Ruffstuff brackets on mine and bought everything else at my local auto parts store. I have less than 300.00 in it with all new parts.
11-11-2013, 12:37 PM | #14 |
Here's a link. http://www.ruffstuffspecialties.com/...g/EHO5272.html
11-11-2013, 01:19 PM | #15 |
DIY4X also sells brackets and calipers
11-11-2013, 04:56 PM | #16 |
it appears that most use the 71-87 ¾ ton front calipers. I wonder if the 90-96 big brake Corvette rear calipers will work. That way you could have ebrake and 4 pistons.
I have sent a request to ruff stuff to ask this.
11-11-2013, 05:41 PM | #17 |
Update: Ruff Stuff reccomended the 77 El Dorado rear brake calipers.
11-11-2013, 08:23 PM | #18 |
if i go with the rear disc kit, do i need to change my porportioning valve?
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
11-12-2013, 09:05 PM | #19 |
I believe so, but dont quote me on that
11-12-2013, 10:15 PM | #20 |
you are supposed to. at first I didn't change mine when I did the front conversion. it stopped much better after I did the proportioning valve. I imagine you'll get a gain in performance out of the rear when you change the valve.
11-13-2013, 10:08 AM | #21 |
what do we change the prop valve to? I know if you put front discs on you have to use a prop valve from a truck that originally came with discs. so if w put 4 wheel discs on would we have to use a prop valve from a newer truck or one from a Cadillac?
11-13-2013, 12:57 PM | #22 |
I bought Blackbird's kit with the 77 El Dorado cailpers with parking brakes a few years ago. I originally used a disc/disc GM master cylinder with the stock 9" dual booster. I also used an adjustable valve for the rear and a 5 PSI residual valve. If you look online, it is recommended that a 5 lb residual valve is used for the el dorado calipers because of the parking brake spring retracting the pads from the discs. The residual valve keeps the springs from retracting too far.
When I first set up the system, the braking sucked. It was unsafe. The issue with the el dorado calipers is that you have to properly adjust the parking brake to so that the pads are close enough to the discs so that the rear line can actually build pressure. My problem was that I would adjust the parking brake, get a couple good stops, and then the calipers would be out of adjustment. I fought it for about a year. I finally spoke with someone who said many of the rebuilt calipers don't have rebuilt piston ratchet mechanism, therefore the pistons won't hold their position after a few braking attempts. One of the calipers I received from Blackbird was such an improperly rebuilt or defective caliper. I went to Napa, bought a new caliper, installed it, and now the truck stops very quickly and extremely straight. The parking brake also holds very well. I had been driving this truck for 20 years with the stock drum/drum combination and can definitely say that this has been a very good upgrade. After my experience, I believe that it is poorly rebuilt calipers that give the El dorado parking brake calipers such a bad reputation. Also, the rear residual valve is also overlooked. Standard calipers don't need the residual valve and therefore it is assumed the Caddy calipers don't need them either. I now have a Wilwood 1 1/8th master cylinder with their adjustable proportioning valve. I think that being able to adjust the rear is also important to get the proper rear bias. |
11-13-2013, 01:32 PM | #23 |
11-13-2013, 01:41 PM | #24 |
has anyone ever run an independent hydraulic style parking brake? My buddy and I were messing around with the idea of a separate, smaller caliper (think drag racing brakes), mounted to the front of the rear discs. The e-brake pedal would have a very small, separate master cylinder, almost like a clutch master cylinder, and just pressurize those two smaller calipers and lock them in place. We were just tossing around ideas as Ive never had good luck with the cable operated parking brakes
11-13-2013, 03:38 PM | #25 | |
