Braided fuel hose
I bought some with the the AN fittings, whats the best way to get the fittings on the hose?
You get what you pay for
![]() Join Date: Dec 1999
There's no such thing as a best way. Whatever works best for you. Tape the ends when you cut it to help keep it from flaring so bad. Then you'll have to work all the wires under the fittings. All I can say is keep a rag handy. You'll be bleeding like a stuck hog before long.
Mike 1985 Chevy C-10 |
#3 | |
Lol. I got that down. Yikes. Thanks Mike So I'm taking about 1/2 inch of the braided wiring off the hose, this way I can slide the fitting on the rubber and tuck the braided end under it. Sound right? Last edited by 85Silveradoin04; 06-18-2004 at 10:28 PM. |
No, you leave the braid on the hose all the way to the end. Just trim any ragged wires off so they don't stick out too far past the rubber hose. Also, clamp it in a vise with a rag to keep from scarring the fitting. Use some oil on the fitting to help it slide in.
Hold on a little. I'll scan a page from my Aeroquip catalog for you. Mike |
To then end eh? I tried that but it was real difficult. I did manage to scar the inside of the fitting do to the ragged wires that got loose. I appreciate the image it will help alot.
Will the fitting be OK? |
Yes. The inside of the fitting where the two go together won't matter if it's scarred. Yes, it's real difficult. The sealing part is the tube part of the fitting which goes inside the rubber hose. Then when it's tightened together, the pressure seals everything off.
Garage Queen Material
yeah, those hoses will poke you bad
