"brand new second-hand"
cooling fan set-up-whats the hot ticket?
I have been searching for the best electric fan set-up for my 69 truck. I have read about using a Ford Tarus 2 speed fan as it is the most econmical and effective set up. I also understand that this is a puller fan set up. I have a rebuilt stock 454 with all the stock factory brackets, a/c fan,runs fine-no over heat issues, fresh radiator(4row) and the truck was an orginal a/c truck. The stock system works fine until you use a/c and get into stop and go traffic. I always thought it was best to leave all the stock cooling in place and add a "helper" fan on the a/c condensor. This would give the cooling needed at highway speed and the aux fan would help in traffic. I guess my question is what has been done by you guys to make the best situation work? I like to leave everything looking as neat and tidy as possible. Did I mention I am on a budget too! Can I use the Ford fan and make it a pusher instead of a puller? I do have a trans cooler on the passenger side of the a/c condenser as well-any thoughts?
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
Junior Member
Re: cooling fan set-up-whats the hot ticket?
Here is what GM did on my '92 GMC K-3500 when they built it. It has a clutch operated fan on the engine.
In front of the a/c condensor is mounted a aux fan that is activated by a temperature switch in one of the cylinder heads. Some thing similar should work on your truck. I am not sure what stock fan will work as a pusher, but I am sure some one will chime in. I know Jegs and Summit has aux fans that can be pushers or pullers, but they are not real cheap. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Ttt
a properly sized and maintained cooling system with properly tuned engine and a conventional motor driven fan is the cool solution i've found to b trouble free for many years
![]() Join Date: Apr 2001
I remember reading on here somewhere that a late model Jeep grand cherokee fan is very similar to the inside diameter of a stock fan shroud. I though i remembered seeing pics and you could hardly notice it was there... just an idea....
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
or do you mean....whats the cool ticket......
I just did the jeep fan install last weekend. Search "another cheap electric fan" and you will find it. for less than $100, fan + adjustable control relay + misc hardware, i am pretty satisfied with it. it puts out far more air than the mechanical fan. but for peace of mind, cdowns is right. and i could have actaully ran both the jeep and the stock mechanical fan if i wanted too, there was about an inch of clearance between the two. i took pics, but i never up loaded them. Last edited by dznucks; 06-08-2010 at 12:47 PM. |
That's right, it's Copper!!
Check this out, same system I used in my truck. I'm very happy with it.
http://www.classictrucks.com/tech/03...all/index.html
Tom: ![]() 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
A lot of members here use our kit. Here is a link:http://www.classicheartbeat.com/radi...&__related.htm
WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
I went with a flexalite and in miami @ 97 degrees with the a/c on the temperature does not go pass 160 degrees.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
*** That's interesting ***
I've done a few mechanical + electric fan setups that use a stock 7-blade mechanical fan and clutch on the back side with a pusher electric fan on the front side. Works great and retains that stock look. As long as you have a good mechanical fan (that works well without the A/C being on), you should setup the electric fan to run only when the A/C is on AND the temp goes above a certain point usually 15-20 degrees above your thermostat temp. You could also tie this into the "high head pressure" switch on your A/C system if you have such a switch. This switch will only turn on the fan when the A/C system is struggling (ie: in high temps causing high head pressure).
You don't want a pusher electric fan running unless you are essentially sitting in traffic. If an electric fan is energized (esp. a pusher) while you are moving at speed, it will wear out the fan motor quickly (usually eating the brushes).
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 06-08-2010 at 05:24 PM. |
#11 | |
Hollister Road Co.
I don't have ac in mine but this is the fan setup I use. http://www.thehollisterroadcompany.com/MarkVIII.html |
#12 | |
Location: Help! I'm in an office park with its own network of freeways!
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
#13 | |
Hollister Road Co.
Its about 4.5" but you can use a Taurus fan which is thinner by about an inch and then off set the fan. A flex fan is quieter because it doesn't pull as much air as a stock fan. |
#14 |
simplify simply simplify on a class truck.......
i am running the factory 7 blade fan from my dad's 72 burb on my own 72 burb. has a 307, 3 on the tree, 3/4 ton 2wd, 4 core radiator, q-jet and plans to tow the family camper ('71 holiday trav'ler). truck will be getting a 406sbc swapped in and cooling will not be an issue as there is no electric motor or fan clutch to "give up the ghost"... |
#15 | |
I ran a Derale dual electric fan setup when I had the 400sb in there. Those poor fans couldn't keep the engine as cool as the mechanical fan had (it wasn't original; I think it had a Mopar part number). The controller burned up a few months later too. I'll have to look around the yards for either a Mark VIII or Taurus setup. Maybe I'll be able to offset either one enough.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* Last edited by CE20934; 06-08-2010 at 11:35 PM. |
#16 |
![]() Join Date: Aug 2004
I've got the Mark VIII fan on my 454, cools just fine even with the a/c on in Texas last summer.
I'm running the short water pump and had to trim the fan and offset it to the driver's side. You might not clear with a long pump.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 06-09-2010 at 12:21 AM. |
#17 | |
'72 cheyenne super step, '05 long bed gmc |
#18 |
Enjoying left field
Sorry to hijack, but I had a quick question. The winters here can get down in the teens or sub-teens and stay there for a week or two. I'm thinking an electric fan would work better in this type of climate since it will let the motor warm up. Am I right, or am I missing something?
#19 |
sounds right to me. It will atleast let the water in the rad heat up quicker
#20 |
i have a BB and bought some 2000 camaro fans, they are electric dual fans, you can get the v6 or v8 ones, they are exactly the same... i got them for $50 out of a salvage yard,
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
#21 |
Between Trucks...
I don't trust electric fans. I'm running a nylon flex fan. Keeps me at 190*.
Beat it to fit, Paint it to match... ![]() |
#22 |
Are you running the short or the long water pump?
#23 |
I really think the trick in getting electric fans to cool properly is in how your shroud tunnels the fans around the radiator. With a properly built shroud a dual electrical fan setup will cool a big block w/AC even in Arizona heat conditions. Members on the site have commented on this several times in the past.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#24 |
Hollister Road Co.
#25 |
thanks for the tip, looking to convert to an internally regulated alternator along with electric fans all at once soon
