City's Articulation Ramp
Steering box frame repair
I eventually will be doing crossover steering, so there will be a lot less stress on the frame, but I was in there today and realized the frame had cracked before and the last guy had tried to weld together to fix it. Anyways it has cracked again. I need a frame repair kit but they are 65.00. I have a sheet of 10 ga plate. Could I cut that up and weld it in? Correctly weld the frame, weld in a inner piece and an outer piece? Does anyone have a diagram for the shape of it, or does it not have to be exactly like the pre manufactored ones? Any input would be appreciated. By the way, it is a 85 1/2 ton swb with 8 in lift and 38.5x15 on 3/4 axles.
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy 00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver 06 Harley Sporster 883 low 19?? Zamboni, Really I own a Zamboni! "If your gonna be stupid, then you better be tough." |
the contours are pretty severe, i doubt you'd be able to recreate it very cost effectively. however you decide to fix it, i would highly recomend a brace to go with it. only makes sense to me to do everything you can possibly do to prevent it from happening again. here's a link to one on EBay. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2481489379
edit: i didnt thoroughly read your post, i just noticed that you have crossover. since it puts more lateral loads on the frame than the standard front to back steering, the brace is a must. Last edited by 1FaastC10; 06-10-2004 at 09:23 PM. |
#3 | |
![]() i think you would get away with using your 10ga. my frame broke and that is pretty much what i used. it has worked just fine, though mine isnt welded, it uses the bolts for the steering box.. i plan on redoing it eventually. a sheet on both sides should do fine, and if you are any good with a welder you could make you a brace as well. |
I will definitly make my own brace, $110 on ebay, that means $150 in the real world. Now the hard part, my skinny ass removing a 38 inch bogger to get to the frame more easily!
Land Beast
http://offroaddesign.com/catalog/steeringkit.htm checkout the stuff from ORD I got my brace from them and works great. the other brace on ebay is a member from CK5.com that sells them through his work I think. any ways good luck.
justin
90' GMC 1 Ton Suburban |
Jon, i did misread the thread, but what i said still applies. also, the 10ga might be working on your truck, but you're only turning 32" tires with it. Joey's 38" Boggers are sure to put way more stress than a 32.
i'd personally still drop the coin and have the parts that are known to work, rather than trying to rig something that might work. Justin, Tim actually has his own business now, makes for nice discounts on truck parts. |
Land Beast
didn't know tim has is own business I'll keep him mind next time I need something.
Granted I will still use a brace, but the stock frame is 1/4" thick, and I will add a piece of 1/4" inside and outside. That would make the frame 3/4" thick there, with the pressure more evenly spread out (if I use a piece that is about 2" longer front and back) and the load will be at a different angle that the brace will now hold. Do you think that still won't be enough?
Weld the cracks together on the frame first, grind them out in a "v" pattern and weld them up. I simply just welded mine up and install the bolt in brace from ORD. I cracked the frame on my 1/2 ton with 31" tires...
I think since you have pretty big tires I would weld that plate in there and then get a bolt in brace, they recommend using both methods with tires larger than 37".
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
I went ahead and order a frame repair kit from JCWhitney (Had a 15% off catalog) and will weld that in. See I counted my chickens before they hatched, I removed the steering box to realized the frame flares out at those bolt holes, isn't flat like I thought, so I would have had a hell of a time making my own plate to match that flare. I did decide to make my own box brace, after studying the manufactered ones, I realized I could make my own with the metal I already had. I could make one using about $10 in material, where the going price is $110 for a premanufactured one. I also order my crossover steering kit from BlackBird customs, best deal I could find. I would have made my own frame repair kit and crossover setup and saved myself about $250, but with working one full time and one part time job, I just don't have time. Can't want to get that back together and drive it again, these little cars are driving me up the wall.
Re: Steering box frame repair
Does the frame repair kit also work for 2wd drive trucks?
Pretty sure the frames are 3/16s and the 1 tons are 1/4in but then again who's arguing =-p
I would also use ord's piece because its already contoured for the frame
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#13 |
Yes the frame repair will fit a 2wd frame.
Posted via Mobile Device |
