Old 05-06-2021, 12:41 PM   #1
1972 C10
1972 C10's Avatar
Pontiac swap
I apologize for posting the same question again, but I still have no clear answer. I want to install a 76 Pontiac 400 in my 69 GMC originally 305 V6. I really want this to look factory and have found vague references as to what frame "towers" to use but would love to hear from someone who has done this w/details.
THANX
64 Chevy Suburban/Carryall 4x4
72 C10 Highlander LWB
34 Chevy 5 wdo Street Rod
64 Corvette Roadster w/AC
78 TransAm WS6
78 GMC Jimmy 2WD Slammed SOLD!
1972 C10 is offline   Reply With Quote
Old 05-06-2021, 01:24 PM   #2
kwmech
Re: Pontiac swap
short search found this
https://67-72chevytrucks.com/vboard/...ac+engine+swap
Old 05-06-2021, 01:46 PM   #3
sick472
sick472's Avatar
Re: Pontiac swap
I reread your older post and it seems you are looking for some OEM parts to make the transplant. I don't know if this is possible. Olds used some Pontiac motors in cars (and/or vice-versa), but I can't help but think that those mounting parts would not bolt up in a truck. I'd love to know better, if you have the info.
But, I did put a Pontiac 400 in my truck. I think the block was a 70 or 71. Here's the story...I went to buy some C10 parts from a guy and one of the longhorn trucks had a Pontiac 400 in it...loving the Pontiac motors, I bought the motor, trans, and mounts...many years later, I have a Pontiac 400 C10.
I know very little about the parts I purchased. The rubberized mounts are definitely Pontiac. I think the towers are Pontiac too, maybe late 70’s firebird mounts. The Pontiac 400 that I purchased out of the longhorn was a YX block which may help determine what car the tower brackets came from IF the Pontiac parts all came from the same donor car. I would estimate that the motor/fan sits about an 1 to 1-1/2" higher that the original Chevy 350 as I had to relocate the Chevy fan shroud upwards in order for it to work properly. There is only one fabricated piece and it is the flat plate that connects the top of the tower to the frame. Here's some photos...
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 05-06-2021, 01:48 PM   #4
sick472
sick472's Avatar
Re: Pontiac swap
Flat plate that connects the top of the tower to the frame photo...
1972 C10
1985 K20
Old 05-06-2021, 01:55 PM   #5
sick472
sick472's Avatar
Re: Pontiac swap
I just got mine on the road a few weeks ago. Here's some encouragement...
1972 C10
1985 K20
Old 05-06-2021, 02:07 PM   #6
sick472
sick472's Avatar
Re: Pontiac swap
Side notes:
1.) I had to move my V8 x-member and shift linkage bracket back to the more rear set of holes in the frame to accommodate the TH400, but all the auto shift linkage parts worked fine.
2.) You may want to put the battery on the other side so the battery cable is not so long and snaking around. I bought the auxiliary battery box and tossed the passenger side one as it was toast.
1972 C10
1985 K20
Old 05-06-2021, 02:41 PM   #7
BigBird05
Re: Pontiac swap
My thoughts are to change the towers over to 73 and up. Then you could use the frame brackets and motor mounts from almost any Pontiac V8. Probably best to get a donor car for radiator, brackets, hoses, wiring etc.
BigBird05 is offline   Reply With Quote
Old 05-08-2021, 10:41 AM   #8
Re: Pontiac swap
I need to save this thread. Great info. I have a 327 built for my '67 GMC project, but still toy with the idea of going Pontiac. GMC began use of V8s in '67 but I think it was later in the year. A GMC/Pontiac marriage just seems natural
Old 05-08-2021, 12:25 PM   #9
1970cstblazer
1970cstblazer's Avatar
Re: Pontiac swap
Love this. Having owned several Pontiacs over the years, I appreciate the ease of working on, the appearance, and the power of a traditional Pontiac V8.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 05-08-2021, 04:20 PM   #10
Greg58
Greg58's Avatar
Re: Pontiac swap
100% agree, the later model Pontiac V8 engines used a clamshell arrangement, similar to square body truck engine mounts.
Way better than the 60s Pontiac mounts.
I have always thought a Pontiac would be a great truck engine because they make a lot of torque.
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
