Old 02-17-2009, 02:26 AM   #1
project 67 sub
project 67 sub's Avatar
Angry need advise: driveshaft problems i think
ok so i took my driveshaft down to a driveline shop yesterday(the 16th) that builds custom & high performance driveshafts(they have been their a while and heard they do good work). took it down because mine had a wobble while driving. well after i got it back he said that every thing is good to go now but it was pretty bad before he started(he had to fix the splined nub on the end cuz it wasnt welded on strait), drove it for a while like that but not on the freeway. it now has a new carrier bearing and fairly new u-joints still. but here is my question and problem: when i drive it on the freeway it feels like it is vibrating pretty bad and i dont know why because i just had it fixed, is their anything else that i can check that can cause this?
any help at all would be very much appreciated
project 67 sub is offline   Reply With Quote
Old 02-17-2009, 02:46 AM   #2
El Jay
Gone to greener pastures
Re: need advise: driveshaft problems i think
Go back to the drive line shop.
With a 2 piece drive shaft, the front & rear drive shafts could be "out of phase" if you separated them to take the drive shaft home.
Have him/them get everything balanced and then index the front/rear shafts so you know how they go together, when you get it back home to the truck.
I hope that made sense, if not, PM me or add to your thread.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 02-17-2009, 03:24 AM   #3
project 67 sub
i had him take it apart and put it back together. the rear shaft is a new slip joint style i bought from cpp a while back.>>>http://www.classicperform.com/Store/...ruck/CPSSD.htm
Old 02-17-2009, 03:32 AM   #4
El Jay
Oooops.
I freely admit that you have surpassed the scope of my knowledge.
But I would really like to know how you solve the problem
Old 02-17-2009, 03:37 AM   #5
project 67 sub
hahah no problem bro. I would really like to know how to solve the problem as well and if i find out i will let you know
Old 02-17-2009, 04:05 AM   #6
El Jay
I would truly appreciate that.
Old 02-17-2009, 04:06 AM   #7
project 67 sub
are you having the same problems to or someting simular
Old 02-17-2009, 04:08 AM   #8
El Jay
No.
But when it comes to things like "our trucks" I just like to have as much knowledge as I can gather crammed into my little pea sized brain.
Hope that made sense to you.
Old 02-17-2009, 04:15 AM   #9
project 67 sub
oh yeah it made sense cuz im the same way. lol.
Old 02-17-2009, 08:38 AM   #10
see ten
WTB this ad
see ten's Avatar
Have you already ruled out a bad tire/wheel/shock? They're all things that coud cause a vibration at one speed but not another.
see ten is offline   Reply With Quote
Old 02-17-2009, 09:05 AM   #11
my67chevytruck
Under Construction
my67chevytruck's Avatar
Originally Posted by see ten View Post
have you already ruled out a bad tire/wheel/shock? They're all things that coud cause a vibration at one speed but not another.
x 2 ! , I have also had slightly bent/warped axles cause vibrations as well....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-17-2009, 09:13 AM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would say take it to the driveline shop and let him drive it.He's the pro(expert is a different animal).He should be able to tell you what is going on.
When I'm stumped I always go to the pros,usually the ones on this BB but drivelines are kind of like carbs.They seem like black magic to those of us who do not know.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-17-2009, 09:52 AM   #13
sick69
sick69's Avatar
Something to think about,,,
If the yolk was not on the ds straight and you drove it that way for and extended period of time it could have caused damage to the pinon bearing. If the ds was bad enough just that wobble could cause pinon bearing damage aswell.
I would take it back to the shop for them to drive and check out on the truck. Hopefully it will be something simple and they can take care of it while you wait.
Just a thought,
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 02-17-2009, 10:27 AM   #14
acl
acl's Avatar
If and when you rule out the driveline, and if you still have an issue, check your flywheel/flexplate. Have you had this problem for a while? Have you changed fly/flex? I fought this same problem for sometime doing just what you are doing, replace this, balance that, and some smart bguy on this board suggested the flywheel and it looked fine but changing it took care of my problem. Good Luck. Gary
acl is offline   Reply With Quote
Old 02-17-2009, 10:54 AM   #15
brad_man_72
the boat guy
brad_man_72's Avatar
we ballanced a shaft for a guy 3x, turned out that his pinion yoke was very offcast (a lot of its mas was off to the side).
after working in a driveline shop i realize that theirs alot more to making a driveshaft work other than just making it fit.
it never hurts to double check things like are all of the ujoint keepers in properly, is the rear joint centered in the pinion yoke, and signs of hitting anything with the driveshaft.
take te truck back to the same shop you had it ballanced at. a reputable shop should check the ballance for free, if theirs no signs of damage. guys that see this stuff everyday know what to look for.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-17-2009, 12:36 PM   #16
cdowns
cdowns's Avatar
a couple of overlooked things are trailing arm bushings and panhard bushings as well as pinion angles if truck is raised or lowered. rearend bearings too
Old 02-17-2009, 01:18 PM   #17
bbarooo
bbarooo's Avatar
I just dealt with this issue and the culprit in my situation was a worn pinion yoke. The u-joint had just a tiny bit of play side to side. Only noticed at speeds above 60mph.
Does the vibration occur in nuetral as well?
bbarooo is offline   Reply With Quote
Old 02-17-2009, 01:36 PM   #18
project 67 sub
all the shocks are still fairly new and the tires are not that old as well. the vibration that i have i dont feel it in the steering or anyting but i feel it through the floor boards all the way up into the seat
Old 02-17-2009, 01:46 PM   #19
project 67 sub
no i never had this problem until i sheared the splined nub off the front driveshaft, and had another one welded on buy a buddy. i eyeballed the hell out of it to get it as strait as possible for a temporary fix but never drove it on the freeway, and only at lower speeds of about 40 were it didnt vibrate to bad. the flywheel should be fine because when i changed the trans a while back it was fine
Old 02-17-2009, 01:49 PM   #20
project 67 sub
only at about freeway speeds (its pretty bad)
Old 02-17-2009, 02:23 PM   #21
acl
acl's Avatar
If this just started since your driveline break I agree it should not be the fly/flex plate. Who knows. You mention above that you "eyeballed the hell out of it to get straight as possible" if you are talking your driveline from rearend to transmission, that might be your problem. Your driveline should not be straight. I not sure of the actual number but plus or minus 3 degree comes to mind. It has been mentioned a couple times before about pinion angle i would check that. If thats not the "straight" you are refering too let us know. I am not the smartest by any means and correct me if i am wrong, but i believe if your driveline is straight with no pinion angle, it could be a factor. Gary
Old 02-17-2009, 03:08 PM   #22
project 67 sub
have a 2 piece driveshaft. when the front half broke time i eyeballed the hell out of the splined nub on the end of the driveshaft to make sure it was as strait as possible by eye and welded it up for a temporary fix. my rear half is not striat and level that i know of. i dont know what the pinion angle is at but the rear end is lowered with 2" drop springs and 3" blocks
Old 02-17-2009, 04:19 PM   #23
project 67 sub
think i might have found the problem(almost positive) but not sure. would the front u-joint bye the trans yoke cause it if it has a little side to side play, and should the yoke have any play in it itself? any help at all is greatly appreciated, cuz im trying to make it more reliable and get it ready for a carshow coming up on the 14th
Old 02-17-2009, 04:21 PM   #24
brad_man_72
the boat guy
sorry i lol'd at eyeballed the hell out of it. even if the shaft was perfectly straight, (we dont let car driveshafts exceed .002" on the stub) the one from the factory wasnt, and it was ballanced to compensate for the runout from the factory. so no matter what you do it will vibrate.
so are your yokes/u-joints in time? that can also cause a vibration.
the only way the shaft will ever be right is to take it to a pro have them straghten it if they can, and ballance both pieces together, mark the way they were ballanced and put them back in the truck using the marks.
im not pickin on you, i do this every day and their is no way i could build a decent driveshaft without the specalized tools.
Old 02-17-2009, 04:24 PM   #25
brad_man_72
the boat guy
u-joints should never have any play in them!!! well the crap that precision makes has about .030 endplay when new....
trans yoke will have a little play.
make sure the keepers are in the ujoints properly.
