Old 05-29-2003, 12:22 AM   #1
71elect
Question Which power steering box do I need to use???
I'm trying to convert my 71' GMC 1/2 ton 2wd from manual steering to power steering. I do have access to a 1974 chevy 2wd 3/4 ton power steering gearbox. Can I use the 3/4 ton gear box or will it be to big for the 1/2 ton application( as far as mating up to everything)? The 3/4 ton pitman arm looks to have more of a bend in it than the 1/2 ton, is this swap-able between units? Or should I just look for a 1/2 ton 2wd gearbox instead? Any help is appreciated!!
72Chevy swb 4x4
71GMC swb 2x4
71elect is offline   Reply With Quote
Old 05-29-2003, 01:02 AM   #2
68 Suburban
68 Suburban's Avatar
That should work fine. There is no difference between the 1/2 and 3/4 gear boxes. I put a 76 Box on my 68 burb. I did have to get a 76 pitman arm because it has the bigger shaft hole for the gear box. It was only $20 at autozone.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-29-2003, 01:51 AM   #3
71elect
68 Suburban,
Thanks!! Glad to know that the 3/4 and 1/2 ton boxes are the same. I do have the original pitman arm still attached to the 3/4 ton gearbox. I'll see if I can pick up a 1/2 ton power gearbox pitman arm to fit my application.
72Chevy swb 4x4
71GMC swb 2x4
Old 05-29-2003, 02:28 AM   #4
68 Suburban
I think the pitman arms should be the same? If you have the pitman arm with the box, you should be good to go. I think the only place the arm is different is on the box side, and not the drag link side.
Old 05-29-2003, 04:16 AM   #5
SEVEND2
SEVEND2's Avatar
hmm I changed my 72 from manual to power steering:
had to change the gear box, pitman arm, steering coupler connecting the shaft to the box, water pump to a long pump, change pullies, because they did not line up any more. other than that its ok.
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
