...just another truck junkie..
![]() Join Date: May 2009
My first dash removal
I have a '63 parts cab that I am using for donor panels and such. I also decided to pull the dash for a spare since it was in great shape. It was a chore, but mission accomplished!
Mike "Bear" Shea |
Re: My first dash removal
Was it welded or bolted? Better save that big window panel as well!
2 bolts and a ton of spot welds. Thankfully a spot weld cutter was in my tool box waiting its turn. I do plan to save the back panel as well, I have a future 4 wheel drive project it will be used on.
Mike "Bear" Shea |
Will have to be doing the same thing in the near future. Are all the spot welds on top of dash?
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
The vast majority are but there are a handful on the sides. You need to remove that panel on the inside where the windshield curves up in order to access them. There was also a bolt on each side but those are easy to get to.
Mike "Bear" Shea |
I was lucky enough to find a great unmolested donar already removed. Will install it on the fleetside this summer. So will be watching this thread in case you beat me to the install.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-18-2015 at 11:20 AM. |
Thanx for the response.. Do you have any pics from the panel? Need a mental look..
Post Whore
![]() Join Date: Mar 2013
I wish these dashes were bolted in...would make painting the underneath a whole lot easier. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
doobiebro, I don't have any pictures at the moment of those spot welds on the sides but I can get some of the ends of the dash and do some editing of another cab picture to give you an idea where they are located. It will probably be the weekend before I get it posted up.
Mike "Bear" Shea Last edited by Bears63; 03-18-2015 at 08:39 PM. Reason: Spelling |
Are you welding the dash back in or just bolting?
I thought the double hump dashes were only 60-62?
Nope, the end year was '63 for those. dougf, unless a bracing setup was added I don't see any way beyond welding it back in. Reason is the weld on the front lip of the cab is what keeps pretty much the whole thing rigid. Pulling the dash was really good for getting a better understanding of how the cab was assembled.
Mike "Bear" Shea |
#13 |
Ok, makes sense, thank you.
#14 |
Thanks Bears63, I learn a little more each day.
#15 |
Junior Member
Dang - your 'donor' cab is better than most keepers I've seen.
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
#16 |
It may look pretty good, but the floors and rockers are bad, lots of rust out in the windshield pillars, and the roof is not good. Lots of other stuff otherwise that will be used for 3 other cabs. Plus, I have a good VIN plate and the title. It was originally a shortbox fleetside that I bought for $500 but had been in a wreck. I have pulled a ton of parts off that over the years, even sold some on this forum, and that cab is all that is left of the truck.
Mike "Bear" Shea |
#17 |
It's Better With Nitro
Nice job! It brings back some interesting memories for me.
An entire weekend, and about a week to recover was this one for me about 5 years ago. ![]()
#18 |
Wanna sell the outer roof skin?
1963 GMC swb sbw 5.3/4l60e porterbuilt From middle Tennessee 60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details.. |
#19 |
cheesee, the roof skin is not salvageable. It took some damage at some point. As a note per the forum rules, if anyone has a question on a part and the possibility of a sale, please send me a PM and not ask within the thread. If this becomes a sales thread it will be locked by the moderators.
Mike "Bear" Shea |
#20 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Your cab still looks better than mine!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#21 |
It's great to see someone else working on a LWB C 20 stepside. I just started on my 64. Learning lots and having a great time. Thanks for the posts keep em coming
#22 |
Greetings fellow bc member! I'm doing a 62 stepside longbox. It looks like our usernames are pretty similar as well lol. Any pics of your 64?
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
