Trailer hitch with factory rear bumper for 1968 C10?
I am wanting to put the factory rear bumper back on my 1968 Chevy C10 shortbed but I want to be able to have a rear bumper hitch so that I can tow a very light duty trailer of mine.
What do you guys who have trailer hitches on the back of your truck with factory rear bumper use? I would like to be able to hide the trailer hitch as much as possible which would be cool. What do you guys have on yours if any at all? |
![]() ![]() Join Date: Jan 2011
Re: Trailer hitch with factory rear bumper for 1968 C10?
A 70s Monte Carlo tag bracket is the same size as the C10 and gives you the 'flip down' style tag holder. You could put a frame mounted hitch behind the tag bracket and run your slide through.
But what would you do with your tag while you're hauling.. Humm. I use the tag flip down to hide the gas fill sometimes. Never done it with the hitch personally but.. just a thought. It might cause issues displaying your tag if you have a trailer attached though. Maybe if you had two tags? Put the other one in the back window when you have a trailer?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
![]() Join Date: Dec 2009
There is a Good thread somewhere (about this) on the forum.
Let me search. ![]() ![]() ![]()
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I have a homemade receiver hitch mounted so the hitch is right where the license plate goes. Then my plate is mounted on a piece of 2x2 tubing so I can put it in the receiver hitch when I don’t need to tow anything.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
#6 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Depending on what you want to spend this is available form Western Chassis but other vendors have em too. I have one on my truck and fits great. https://westernchassis.com/1967-72-C...itch-Receiver/
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#8 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Dec 1999
I could not find where it said it wouldn't fit a longbed. But I bet this is some clue as to the modifications, it says "NOTE: Due to space restrictions and variations in frames and bumper brackets some slight modification to the nut plates or bumper bracket may be required."
#10 | |
Moderator
![]() Join Date: Sep 2007
these guys are talking about a hidden hitch... very sleek looking and use these with a fold down lic plate holder found on the g bodies.. (78-87 montes, cutlass regals and grand prix)
you can also use a hitch from a square body if you dont mind the receiver part showing under the bumper. bolts right on , but you do have to drill a couple more holes in the frame is all
1967custom |
My particular hitch was bought in 2003 from Early Classic Enterprises and the guy that installed it put a 1 1/2 inch spacer on the supports to lower it toclear a crossmember and do NPT fitting would clear as well. I dont know if the Western Chassis one is the exact same a mine. I think CPP has one as well.
