Old 02-03-2021, 08:43 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Update on gas tank...
The gas cap mod I did a few weeks ago. I also ordered a new sending unit for it that has the vent tube. I ran fuel line over to the passenger side cab and up into the top then back down out the bottom to the frame. I drilled 2 holes to run a tie wrap around the hose to hold it in place. It should get the smell out of the cab I hope.
I may end up running it to a charcoal canister but haven't yet.
I got the new 453 GenTx mirror installed in the 71 today also. It's a Nissan mirror with Home Link, auto dimming, compass & temperature readings. I even found a easy way to change the read out color to red to match the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
