406 Powered
How's your 20's ride?
Supposed to meet up with a vendor in april in piegon forge to get wheels and tires. I am having second thoughts though as im worried my choice of 18's might not fill the fenders well with the 3.5/5 drop. Hows yalls 20' ride? I see alot of you running 20x8.5 and 20x10's. I have spent hours looking at you guys truck pics. I would love to run the 18's but want it to look right. I was gonna go with 18x8 and 18x9.5. Im also not running a c-notch and really would like to stay away from it. Thanks in advance guys.
70 GMC 68 c10 2002 silverado 72 4x4 |
Tot Roddin'
Re: How's your 20's ride?
Love the ride on my 20's with a 4.5/6" drop with no c-notch.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
I've ran mine with both 15" rallies and with the 20's with a 40 series sidewall (4.5-6 drop). As expected, it rides a little better with the 15's than the 20's. But it rides fairly well either way. As for the notch, I have one and still bottom out from time to time. But you could probably get by just fine without one on a 5" drop. Whether you go with 18 or 20, your truck is going to look awesome!
1970 SWB Build |
406 Powered
I thought a 6 inch drop in rear required a c-notch? Do you ever bottom out?
#5 | |
406 Powered
I know on my 06 Z71 there is a good bit of difference going from the factory 17" rims to the 20s with both tires being the same height.
Posted via Mobile Device |
Old member
I have no c notch and it rides great. 20" all the way around.I do have helper air bags in the rear coils and soon I will have them in the front's as well.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I love my 20's......the y ride like a dream. Granted I have full airbag suspension, so my ride will be a little different than you all running springs and coils.
#9 | |
Tot Roddin'
I have bottomed out once and I was just pushing it to hard and came off a bridge on a local highway. (Lower on the passing lane) Posted via Mobile Device
![]() Join Date: Jul 2012
My 71 swb has the 4/6 kit from ECE with no notch. I have'nt driven it much but it does'nt seem like it will bottom out. Lots of room left.
![]() Join Date: Jun 2011
Love mine
406 Powered
Good to know man. If i have to go 1 inch more in the rear then i will be fine.
