11-26-2003, 10:04 AM | #1 |
truck is leaning???
it seems like my truck leans to the drivers side. I am a big guy, but not that big. Is this something that happens with older trucks? I was thinking about an add-a-leaf, but then i was worried that the drivers side would be higher then the passenger side. I think what would help is an add-a-leaf on all corners. What do yall think?
i think that i have leafs at all corners. I will have to look.
1972 k10 4x4 LWB (Sold in 2005) |
11-26-2003, 12:03 PM | #2 |
Project Junkie! Fishing Poor!!
Sounds like your truck has the Chevrolet Lean. It is quite common in the 2 wheel drive trucks. Although I haven't seen it much in the 4X4s. You could have a couple of things going on.
1.) After 30+ years of use, more weight has been on the left side of the truck causing uneven ware on the springs. 2.) Something real common to the 4X4s, is a broken leaf spring in one of your spring pacs. (Check them for cracks) 3.) Worn spring bushings, (not likely but worth a check anyway) 4.) Broken Shackle. (Again not likely, because you probably already checked for that) The only fix that I know of that wouldn't be considered a bandaid, would be if your springs are not broken, your bushings not worn out, or you don't have a broken shackle, would be to either have your springs re-arched (all of them) or to replace them with new springs (again, all of them.) To replace only a pair may improve the problem, however all of your springs are worn. A temporary fix would be to add spacers between your springs and rear ends, however if you are going to go to that extent I would just replace the springs. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
11-26-2003, 12:27 PM | #3 |
there is a real simple fix to this problem :
GET A FAT GIRLFRIEND !!!!
11-26-2003, 01:40 PM | #4 |
20' Daredevil (Ret)
Nice avatar!
It would take some effort, but you could swap the springs side-to-side, you'd at least know for sure if the springs had weakened & settled over the years. If so, you could even leave them that way, maybe for several more years! Cheap fix... After talking with a bunch of people several years ago, I decided not to re-arch my sagging front springs - I bought new ones.
