Old 12-17-2010, 08:00 PM   #1
camaney
Tranny swap from 4speed to 5 speed what's the easiest
Ok I did a overdrive swap on my truck and told my friend about it but he has a 4 speed low granny and wants to keep it stick. The question is what is easy tranny he can put on his and not hard to find not too expensive? It's a 72 6 cyl 292
camaney is offline   Reply With Quote
Old 12-18-2010, 12:42 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tranny swap from 4speed to 5 speed what's the easiest
I put an S-10 5 speed in my 6 cyl '67. Works great and is really easy if you buy the spacer plate. There are quite a few threads on here about it.
The easiest way to see the threads that pertain to it is to type in - s10 5 speed - in the Google search box at the top of the page, click the circle in front of "67-72chevytrucks.com" and then click on the Google button.
LockDoc
Leon
Old 12-18-2010, 09:49 AM   #3
Wrenchbender Ret
The S10 5 speed is great for swaps like that. They are cheap & plentiful. On the 68 up with the SM465 4 speed the center hole in the bell houseing is larger. You will need an older bell housing.
Wrenchbender Ret is offline   Reply With Quote
Old 12-18-2010, 10:20 AM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I agree with these guys. A 5 speed from a S-10 would be the easiest and cheapest to get in there.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-18-2010, 01:12 PM   #5
mr.chevy
mr.chevy's Avatar
Question, does the s10 bolt right up to the drive shaft? Does anyone have any pictures?.
So what i am in the process of putting a 4 speed with an overdrive. a new process 833 overdrive out of i believe an 83 diesel. Has a hurst shifter also.
Ben
Its a 67 Chevy C10 now, and its short now too.
Here is my 1967 Chevy C10 Shortened Build Blog
http://boyescustoms.blogspot.com
Here is my 1967 Chevy C10 Shortened Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=433535
mr.chevy is offline   Reply With Quote
