Old 06-06-2006, 01:36 PM   #1
Army_Dude
Scrapping the smog (hypothetically of course)
Cause I know none of you upstanding citizens would actuall know how to do this. Anyways, I found out it's true, it's all true. I am currently to return to Iraq in or about November. Soooo, being as there will be no smog inspections here when I return, well you get the point...
Here's the deal, it's an 85 chevy with a new crate 350 from Goodwrench. The intake is stock as is the carb and exhaust.
Question is should I wait till I get headers and a new intake (already got a new carb waiting to install with headers and intake) OR can I just take this crap off and plug the holes? I'm assuming I'll need to dial in the carb again right? thanks guys for any all advise. I want to get all this done prior to leaving so hopefully when I return I can paint and enjoy it.
Army_Dude is offline   Reply With Quote
Old 06-06-2006, 01:48 PM   #2
Jonboy
Slots go on anything!
Re: Scrapping the smog (hypothetically of course)
I think you may be able to just pull it off and cap the holes. If you are planning on headers, I would just do that. It would be really sad if teh exhaust was so bad, it just fell off with the catalytic converter, and you had to install new dual exhaust too. Hypothetically speaking, of course.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-06-2006, 02:00 PM   #3
Army_Dude
No man, the exhaust has been done before. (I got the joke though). The cats were gone before I got it. So it wouldn't pass anyway. I do plan on when I get the headers to replace all pipe. We got a craft shop here on post and they got EVERYTHING. Lift bays, muffler bays, welders, tube benders, they even sell the pipe!. But yeah I just meant the sensors and doodads on the engine itself.
Old 06-06-2006, 03:15 PM   #4
BigDan3131
BigDan3131's Avatar
For the most part aftermarket intakes dont have as many holes as a stock one. Are you just going to leave it stock? or are you going to change cams and such later on?
Chevy Hi Performance magazine had an article a few years ago about taking the stock motor you have and slowly adding parts to make more power. I think it was called the Goodwrench Quest series parts 1-8 or 9. Or if you dont want to lean on your motor find a 4-71 blower and use that instead. It uses One Carb instead of two and you get all the extra torque.
BigDan3131 is offline   Reply With Quote
Old 06-07-2006, 02:12 PM   #5
Army_Dude
Since the motor is new, I'm leaving the cam and all stock. My only plans for upgrade are headers, intake, and distibutor.
Old 06-07-2006, 03:08 PM   #6
Chevrolet4x4s
Chevrolet4x4s's Avatar
What are the inspection standards in NC?How far back do they smog em?What I am getting at is if I would put a diesel in a non diesel truck(pre 87) am I gonna beable to get a sticker without cats or will I have to get some and smash the guts out of them?
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 06-07-2006, 03:23 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
You can pull the stuff that you have off and use the factory exhaust manifolds for the time being. The factory intake can also be used until the right time presents itself, with one exception( The carb that you are going to put on MAY be a square bore carb (Edelbrock of Carter AFB design) and the intake may not be layed out for that design (spreadbore holes in the intake). You may have to get an adaptor to mount the carb. If that is the case, I would look for a different intake manifold and just bolt it on instead.
While you are at it doing the intake, I would consider the distributor at that time. Unless you are going exotic on the "Dizzy", you could get a great amount of performance out of an older style Chevrolet HEI distributor. Just change the weights and springs inside it for a quicker advance profile (cheap kit). When you were broken and setting in my yard, I thought that was what you already had under the hood. When I rebuilt my 383 in the truck I put an HEI distributor fro the "Carb Shop" in my truck and then put the older HEI distributor in my son's Red 86 Chevy motor. I also have found that the Edelbrok or Wiend intakes had all of the holes that I needed to connect everything that I wanted on my motor. I hooked up the brake vacuum to the hole in the back of the carburetor. I then connected a brass elbow and reasonably large hose barb to the vacuum port behind the carb and ran that hose to the firewall. Once at the firewall, I then branched out to the other sources that I needed vacuum for (cruise, heater, etc...). The vacuum for the distributor comes off of the carb on the front (the non-ported fitting), for a quicker advance curve. The other things on the intake for vacuum will be a lost item (forever). The only other thing is the hot water outlet to the heater on the passenger front corner of the intake. I would look at the Edelbrock Performer RPM style intake over the Edelbrock Performer, due to the point where the power curve is the mnost effective. The RPM is about an inch taller and the power curve is from 1500 to 6500 RPM, where the Performer is 0 to 5000 RPM. Keep in mind you really don't start to work your vehicle until the RPMs are above a 1000 anyways.
The exhaust manifold's air tubes can be removed and there are brass plugs that can be screwed into their openings. I originally bought mine at a local parts store. They worked fine for many years, until I installed the headers.
Do you rmemeber what T/stat you installed with the new motor? Get ahold of a 180 degree unit and install it for a better all around temperature on the engine and a better operating mix on the intake air charge to the cylinders.
piecesparts is offline   Reply With Quote
Old 06-07-2006, 04:46 PM   #8
C&C Chevy
C&C Chevy's Avatar
Anyone know what size the plugs are for the exhaust manifold?
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 06-07-2006, 04:56 PM   #9
piecesparts
Something odd like an 8 MM tubing plug. My parts store had them in big bags and they were easy to get then.
Old 06-07-2006, 07:19 PM   #10
C&C Chevy
C&C Chevy's Avatar
Thanks piecesparts!
Robert
Current:
Past:
