![]() Join Date: Sep 2005
Door Weld
Anyone have any expereince welding a crack on the door around one of the door hinge bolting areas? Do they hold over time? Just wondering if they're fixable or if I'm just doomed to always have trouble w/it recracking? thanks.
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 |
Re: Door Weld
Do you have a pic? Why is it cracking?
If it's because rust has weakened the area, then you're hooped, but I'm not sure otherwise why it'd crack. I mean compare how light our doors are compared to a mid-70s Monte Carlo or Eldorado, ours are super-light by comparison.
CAN'T FIX NOTHIN
Re: Door Weld
You can fix it by making an L shaped braket and brace it off the inside of the door no need to weld it just put longer bolts thru it make an L braket out of a piece of thick mmetal drill holes in it to match the holes in the door hinge and put nuts on the inside tighten it up then drill one or two holes in the inside with your door panel off put bolts and nuts on those and it will last forever , comon problem on these trucks people jump out and just let the door go ! Eventually it breaks out around the hinge ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Re: Door Weld
I have had good luck welding up the cracks and they hold over time if you weld the inside and the outside. If the metal is rusted then it will need to be replaced. The ones that I have seen cracked because the hinge pins froze up.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: Door Weld
if you v grove bot sides and ge a good weld it should last lnger than you.
Re: Door Weld
I've always been told drill a hole at both end of the crack then weld it. Supposedly it lessens the chance of re racking
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
Re: Door Weld
Took a pic last nite. Will have to refigure out how to post it. Standby.
Re: Door Weld
That wasn't too hard. Picture is worth a thousand words....
![]() Join Date: May 2003
Re: Door Weld
I would sandblast the area, dril a small hole at the end of each crack and weld it up, making sure the welds penitrate to the bracket on the inside.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Re: Door Weld
Certainly seems to me that an expert welder could easily repair this.
Re: Door Weld
It's a nice door. Good to hear that it can be saved.
#13 |
Re: Door Weld
I bought two doors from AZ and they both needed to be welded in this same area. I'll let you know if they crack again so tune in about twenty years from today, OK?
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
#14 |
Re: Door Weld
I'll put a note on my calendar...
