10-13-2015, 08:37 PM | #1 |
Duramax guys
Looking at a 05 2500hd with a duramax with 160k on it. How are these motors holding up with higher milage on them.
12-18-2015, 01:14 PM | #2 |
Re: Duramax guys
185,000 miles on mine. Only thing mine ever needed other than regular maint (oil changes, fuel filters) was an alternator, belt and idler pulleys and tensioner. I still running original water pump, I change coolant every 2 years.
04 Yukon XL 2500 w/ Quadrasteer 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
12-19-2015, 06:43 PM | #3 |
Re: Duramax guys
At work we don't have alot of issues out of the older ones. Just make sure to get quality fuel from a reputable station. Injectors are hard to tell when they'll go out. Best way is to look at the balancing rates on a scan tool. There solid trucks and like I said we don't have many issues from them.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
12-19-2015, 09:40 PM | #4 |
Re: Duramax guys
160k is barely broken in for these engines, or for a diesel in general.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-20-2015, 01:28 AM | #5 |
Re: Duramax guys
Typically 300K is the end of the Duramax life span around here. A buddies truck just spit the crank out yesterday at 295K.
12-21-2015, 06:12 AM | #6 |
Re: Duramax guys
I have 145k on mine no issues motor wise. love mine. Lly's are known for head gaskets failing.
01-02-2016, 09:47 PM | #7 |
Re: Duramax guys
We have a customers 07 pulling tri axle 30 ft cattle trailer, with 800,000 km (480,000mi.) on it still pulls 15-16 mpg loaded His 2015 get 7 mpg
04-04-2016, 02:54 PM | #8 |
Re: Duramax guys
My 03 has 233k. The only thing I've done to it is injectors. The 05 has better injectors and much easier to change.
Great engines... I love mine
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
04-05-2016, 02:46 AM | #9 |
Re: Duramax guys
Father has a 05 dmax, they are a great truck. We did a few things to it that are common upgrades/preventive maintenance. We put a 06 turbo mouth piece on it, installed the pump rub kit for the transfer case replaced the stepper motors in the dash cluster and had the injector wiring harness replaced. Now the hydro boost has a leak in it but that's a easy fix. Other wise these trucks are great as long as there taken care of.
1969 Chevy c20(Miss Hackjob) |
04-05-2016, 08:18 PM | #10 |
Re: Duramax guys
04-05-2016, 09:26 PM | #11 |
Re: Duramax guys
04-05-2016, 11:51 PM | #12 | |
Re: Duramax guys
"300,000 miles being the end of a Duramax life span" Is a bold statement. |
04-06-2016, 01:56 AM | #13 |
Re: Duramax guys
Some make it to 300k some don't and some make it further, it all depends on how you take care of it and sometimes luck.
