05-28-2019, 06:03 PM | #1 |
Getting a new windshield.
I’m finally getting around to replacing my cracked windshield.
I have a good glass shop here in Columbia SC, and he’s the one that most recommend for older vehicles. For those who’ve done this, is there anything I need to watch for when they do this? I’m putting the stainless trim on and made sure I have the right trim/seal. I’ve had a leak at both upper corners since I got the truck, and now when I cut away part of the old seal, I see why. Some time in the past, I think the glass was replaced, because there was a bunch of old caulking crap in the corners. I know it didn’t come out of Janesville that way. Well wish me luck on a leak free windshield |
05-28-2019, 07:12 PM | #2 |
Re: Getting a new windshield.
When I did mine it said to put the trim in the rubber on the windshield before installing the glass otherwise you won't get the trim to fit. Just my 2 cents. Good luck I broke the first one.
05-28-2019, 07:22 PM | #3 |
Tape the trim on about every 6" all the way around the windshield with blue masking tape (obviously after the rope has been placed in the gasket). The rope will cut through the tape as it is pulled over the lip. If you don't, the trim will often pop out before the windshield is fully installed. If it does, you carefully take the windshield out and start over again.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
05-28-2019, 08:55 PM | #4 |
We had a highly recommended glass shop do our 72 with trim for a small stone chip. Big mistake, shoulda lived with the chip. It took nearly a month, with them trying various combos of glass, wstrip, trim (and at one point blaming us for not supplying parts). Frustrated, they were close to returning in the truck with NO windshield. Instead we got it back with an amateur RTV job sealing the obviously unseated gasket. Just glad to get it out of shop hell, we live with it. One day, we’ll find another shop, or better yet, do it ourselves following the Precision video:
https://www.youtube.com/watch?v=SOU_0HpS7To |
05-28-2019, 09:26 PM | #5 |
The factory installed them with butyl rubber sealant approximately 12 inches from each top corner. Do not use silicone sealant on automotive glass.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-29-2019, 01:33 AM | #6 | |
I’m really kinda nervous about this after reading all the horror stories and past experiences with shops. Thanks to all for the tips and advice |
05-29-2019, 07:37 AM | #7 |
x2! And don't use silicone anywhere on anything. I hate that crap. It was invented for aerospace decades ago and I bet they don't use it now. There are many better alternatives now... where using caulk is proper. Usually when I see silicone it was a failed attempt to fix a leak the EZ way when all it did was make matters worse for the one doing it right after the fact. It is a material the is incompatible with just about any other material on the planet. Once used, you are screwed for using anything else/better such as urethane or tri-polymers. They don't glaze high rises with silicone. That job NEEDS to be done right!
05-29-2019, 08:41 AM | #8 |
I just watched 2 very good videos last night on YouTube with step by step instructions.
05-29-2019, 09:07 AM | #9 |
Carpe manana
My advice is don't even bother with reproduction stainless trim, you'll regret it. Use OEM trim. Good luck.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
05-29-2019, 09:17 AM | #10 |
Proprietor of Dale's Corner
Do you have links to them?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-29-2019, 10:34 AM | #11 | |
The Older Generation
^^^^ This!!! They probably won't get it installed if you have aftermarket trim. "Precision" rubber gasket & original trim all the way...... LockDoc
05-31-2019, 10:41 AM | #12 |
Well, I drove into the shop to get my new glass today, and as soon as the “Tech” stepped out, he says “I’ve never done one of these, and you gonna haf to put that chrome trim on yourself”.
I wasted an hour, and 30 miles worth of gas. Now I have to go back on Tuesday, when they’re bringing a guy in just to do it. LocDoc, I do have a Precision seal and the factory stainless trim. And I made sure that they match up.(knowing that there’s two styles, 67-70 and 71-72) That was another headache in itself, trying to explain this detail to the clown behind the counter at the parts store. I don’t expect much. I just want my new glass, and I want it installed right. |
05-31-2019, 01:23 PM | #13 |
Let us know how it goes . And if it works out ok what brand of glass was used.
05-31-2019, 01:30 PM | #14 |
I dont know why your not doing this yourself, watch a few youtube videos, read as many windshield install questions. 20 ft 1/8" cord, water, dish liquid , tape to hold the trim in. You will know more about it than the guy your paying to do it, helps to have 2 people... Good luck either way. $6.00 set nylon tools from harbor freight would also help.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
05-31-2019, 01:38 PM | #15 |
05-31-2019, 02:31 PM | #16 | |
I was told this guy the shop has coming goes around to several locations as needed, to install glass in the older cars and trucks |
05-31-2019, 02:45 PM | #17 | |
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-31-2019, 05:00 PM | #18 |
This is the Precision YouTube link that is the most detailed video about our windshield installations.
Well worth the watch. https://www.youtube.com/watch?v=SOU_0HpS7To |
05-31-2019, 11:17 PM | #19 | |
I never try it with less than two people (usually three). I have installed a lot of them..... LockDoc
06-01-2019, 02:44 AM | #20 |
X2 on having a helper
06-01-2019, 08:01 AM | #21 |
Precision video.
I did mine myself with one helper. I used glass from Summit, Precision rubber, and got the stainless trim aftermarket. It was a pain in the ass but I’d rather do it than tell a glass shop guy that’s never done one how to do it. |
06-01-2019, 11:44 AM | #22 |
Does anyone have a Brand Name for this Butyl Sealant. I just got back fro the AP store and they don’t carry it. I wondering if either NAPA or the Paint Supply Store near me might have it.
06-01-2019, 12:20 PM | #23 |
I was able to find butyl tape at Home Depot. Also could try a glass shop
06-01-2019, 01:48 PM | #24 |
I have the precision windshield seal and prescision's aftermarket stainless trim. This is the second windshield seal and stainless trim I have purchased. I had my neighbor help me attempt and install with the Counterparts brand seal and trim and we broke the mother! I said, ok that can't happen again... I bought a new windshield and have had 2 mobile installers come by to put the windshield in. They both complained about the counterparts brand and recommended Precision. I bought the precision brand seal and trim as I stated above and had the guy come back out. Guess what... he still said the trim will not work! He left and said he would come back and try again... a week ago. The precision video on youtube uses the original trim in the install... I was like WTF? They sold me the aftermarket junk that doesn't have the proper depth and then they use the original trim with the proper depth in their install video??? I have sent two "pro's" running away from this install.
06-01-2019, 03:09 PM | #25 | |
https://www.amazon.com/CRL-Windshiel.../dp/B000K40PGA Apparently 3M no longer manufactures their brand of sealer. I've seen some in caulking tubes, but I never tried them.
