Old 09-18-2006, 08:42 PM   #1
rapidride3
eliminating carrier bearing in 76'
I have a 76' cheyenne longbed fleetside with a turbo 350 trans and a 12 bolt rearend. I want to eventually add a 700 r-4 from bowtie overdrives. I want to eliminate the 2-piece d-shaft and carrier bearing. I had an 83'gmc with a 700 r-4 and 10 bolt with a 1 piece shaft. I really liked the simplicity of the 1 piece shaft in my 83'. can this be done once i put the 700 r-4 in my 76????with the 12 bolt???
rapidride3 is offline   Reply With Quote
Old 09-19-2006, 04:42 PM   #2
rapidride3
Re: eliminating carrier bearing in 76'
Has anyone ever done this?
Old 09-19-2006, 09:44 PM   #3
79Silv4x4
Workaholic
79Silv4x4's Avatar
Contact Bowtie overdrives. Their tech folks are great and should be able to advise you on this. . .
79Silv4x4 is offline   Reply With Quote
Old 09-20-2006, 06:11 AM   #4
Ziptar
Diesel Addict
Ziptar's Avatar
If it turns out you can do this, I am looking for a 2WD 2 piece Long bed TH350 12 Bolt rear driveshaft so I can put a 700R4 in my 79. I'd be interested in your old driveshaft.
If you can use it my 85 2WD parts truck that has the 700R4 in it that I am going to use has a single piece drive line in it now, I'll trade you if it works for you, it's a long bed but has a 10 Bolt rear.
1979 C-10 Silverado w/ Olds 5.7L Diesel
Ziptar is offline   Reply With Quote
Old 09-20-2006, 08:38 AM   #5
mister honey
I'm planning on this change in my '76 longbed, too.
I talked with a driveshaft shop and they said a straight driveshaft would be OK as long as the distance between the U-joint centers from the trans yoke to the rear end yoke were 65" or less.
Mike
mister honey is offline   Reply With Quote
Old 09-20-2006, 07:28 PM   #6
Ziptar
Diesel Addict
Ziptar's Avatar
I don't know why this didn't hit me before....
DUH!
You can use a single piece driveline form any 73-81 Long bed 2WD Pickup as long as it came from a truck that had a 12 bolt rear and a TH350 and the TH350 has a 9" Tailshaft (which 99.9% of the pickups do.). It'll work with a 700R4 with no cutting or modding, the TH350 and 700R4 Splines are the same (well there were 27 sline 700R4s but they were like hen's teeth).
Check car-part.com for yards in your area, Search for one for a 1976 C-10 2WD 131.5" Wheel base TH350 Single piece, you'll find a bunch I bet.
Old 09-20-2006, 11:00 PM   #7
rapidride3
thanks thats the "easy answer"i was looking for. I like those kinds of answers!!!
Old 09-21-2006, 05:24 AM   #8
Ziptar
Diesel Addict
Ziptar's Avatar
No problem, let me know how it works out. Like I said up top, I could use your old drive shaft if you wind up swapping.
Old 09-21-2006, 05:13 PM   #9
rapidride3
It might be a while however i wil let you know.
