02-16-2007, 08:10 PM | #1 |
The Best Member
Gas Pedal Arms
Does anyone know if the gas pedal arms are different between 67-72? I know they were on the floor from 67-70 I was just wondering if the pedal would still fit on the arm of off a 71 72?
70 shortbed C10 -------SOLD------- 1972 Chevy C-10 l/b |
02-16-2007, 08:20 PM | #2 |
GMCDAC
Re: Gas Pedal Arms
Hey bgang- all I know is my 2 GMCs, and the 70 uses a linkage setup, and the pedal mounts to the floorboard on 2 screw in balls. The 72 has a free hanging pedal from a pivot that pulls a cable. Dont know if its the same for Chevy but dont see why not. Also dont know if they made the switch in 71 or 72.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! |
02-16-2007, 08:48 PM | #3 |
Active Member
Re: Gas Pedal Arms
Can't really answer your question, but do know that for my 1971 I used the arm/brackets off from a mid 90's Chevy pickup and it looked to be exactly the same.
1971 SWB SOLD
02-17-2007, 09:51 AM | #4 |
Re: Gas Pedal Arms
The 72 I pulled my parts from had the suspended pedal. I pulled it out to try and make it fit in my 68. It's not a direct bolt in deal, but you make it work if you smooth and fill the old place on the firewall then redrill all the holes. Just make sure to make a template off the 71/72. I didn't want to go through all the work on mine so I put it back in when I sold the 72.
02-17-2007, 05:06 PM | #5 |
The Best Member
Re: Gas Pedal Arms
ttt
02-17-2007, 05:57 PM | #6 |
Re: Gas Pedal Arms
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
