Radiator Fittings For Transmission
Do I Need To Use Inverted Flare Fittings On The 2 Transmission Cooler Ports on The Radiator Or can They Be Npt Fittings With No Flare..
Running AN Lines To The Transmission and To My Auxiliary B&M Cooler |
![]() Join Date: Mar 2003
Re: Radiator Fittings For Transmission
They need to be inverted flare to seal properly
![]() Join Date: Dec 2009
You need the inverted flare.
In your case the inverted flare will give you a double seal. They make the fitting you need. You just have to find out the threads you have in the radiator. Then what AN size you want to use preferably same size as your cooler you will be adding. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
