Old 01-25-2013, 03:20 PM   #1
MFCopenhagen
MFCopenhagen's Avatar
Help Diagnose Brake Issue
Brand new to the forum here...and brand new '69 owner (don't yet have a build thread).
I just bought the truck this week and need a quick list of things to check on my brakes.
Driving the truck home, I'd apply the brakes and it was like trying to stop on an icy road. I had to be really easy on the pedal. It's had a front disk conversion.
I haven't had really a chance to spend quality time checking everything out and I'm definitely not a brake guy.
Hoping to get some advice on some things to check and maybe some procedures to diagnose the problem. Thanks in advance!
Daisy the Junkyard Duck - 1969 K20 Longbed
MFCopenhagen is offline   Reply With Quote
Old 01-25-2013, 03:22 PM   #2
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Re: Help Diagnose Brake Issue
Trying to stop on an icy road...is it the front or the back that is locking up? I have other questions but will wait for a little more information before I type them all out.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 01-25-2013, 03:25 PM   #3
MFCopenhagen
The backs are locking up.
I don't have a lot of options when applying the brakes...either VERY lightly applied, or start sliding down the road.
Old 01-25-2013, 03:28 PM   #4
BMERDOC
BMERDOC's Avatar
Adjusted too tight? Fluid contamination of the linings? Pull the drums and let us know what you find.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 01-25-2013, 03:33 PM   #5
MFCopenhagen
Starting the project after work tonight and will spend the weekend with it.
I'll take pics along the way and see what I can find.
Old 01-25-2013, 03:36 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
You have a '69 converted to front discs, and the rears are locking up. Make sure you have a (correct) proportioning valve. It's required b/c disc brakes need more line pressure to operate than drums.
Probably should have a vacuum booster also.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-25-2013, 03:51 PM   #7
FirstOwner69
FirstOwner69's Avatar
That's what I was thinking also. Post a picture of the master cylinder/booster setup and it should be easy to tell.
Edit: I see you have a K20. The 3/4 ton setup is different from the 1/2 ton... different master cylinder. Not sure of booster, but I think it's also different.
FirstOwner69 is offline   Reply With Quote
Old 01-25-2013, 04:03 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
This is from a recent thread (not mine). It shows the MC bolted to a booster (big round can with a vacuum line attached), which is bolted to the firewall.
The proportioning valve is not visible in this pic.... it will be on the other side (drivers side) of the MC.
- Mike -
RIP El Jay
Old 01-25-2013, 04:11 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Edit: I see you have a K20. The 3/4 ton setup is different from the 1/2 ton... different master cylinder. Not sure of booster.
Doesn't matter if you're just trying to determine whether you have a vacuum booster. They will differ somewhat in appearance, but are basically the same -- a big round can between the firewall and the MC. Without one, the MC bolts to the firewall.
- Mike -
RIP El Jay
Old 01-25-2013, 04:17 PM   #10
FirstOwner69
Agreed. My suggestion of posting a pic was meant for the original poster to show his setup. Didn't mean to mislead anyone.
Old 01-25-2013, 04:20 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I just figured that out.... I thought I was responding to the OP!
- Mike -
RIP El Jay
Old 01-25-2013, 04:21 PM   #12
MFCopenhagen
I'll get a pic up once I get off work and get home.
--Really appreciate all the help with this.
Old 01-25-2013, 04:35 PM   #13
FirstOwner69
Post #4 in this thread has a pic of the correct original GM setup for a 3/4 ton.
http://67-72chevytrucks.com/vboard/s...d.php?t=510104
Edit: ....and this is a picture of my original 69 3/4 ton setup with drum/drum brakes. This IS NOT what you want.
Old 01-25-2013, 06:28 PM   #14
71K20chevy
71K20chevy's Avatar
This is the prop valve on my 71 K20, disc/drum:
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 01-25-2013, 09:11 PM   #15
MFCopenhagen
Just took this pic...what can you tell me from this?...
Old 01-25-2013, 09:15 PM   #16
chipflyer
chipflyer's Avatar
That's not a prop valve, that's the pre 71 drum brake distribution block. Your brakes won't work correctly until you get a prop valve as shown in the photos above.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 01-25-2013, 09:40 PM   #17
MFCopenhagen
Awesome! I have a starting point!
Old 01-25-2013, 09:45 PM   #18
FirstOwner69
Jeff
Agreed. Plus your master cylinder is like the one I posted in post 13 that's on my 69 with drums. The correct master for 3/4 ton front discs is shown in post 14 (the rear chamber for the front brakes is larger).
Old 01-25-2013, 11:05 PM   #19
MFCopenhagen
In another post I read that the front is larger.
Old 01-25-2013, 11:12 PM   #20
FirstOwner69
The chamber for the disc front brakes is larger. I understand, the front brakes should be connected to the rear master cylinder chamber (the larger one). On the other hand, the drum/drum trucks had the rear chamber connected to the rear and front to front.
Old 01-25-2013, 11:20 PM   #21
chipflyer
chipflyer's Avatar
The front chamber could be for the front or rear brakes depending on weather or not its a half or 3/4 ton, they are opposite! The link below with Livrats excellent info will explain it all very well and should help you decide exactly what you need.
http://67-72chevytrucks.com/vboard/s...d.php?t=214559
Jeff
Old 01-25-2013, 11:36 PM   #22
FirstOwner69
Jeff
The OP has a K20. So, which way was the 3/4 ton master to be connected? I don't think the link to Livrat's post does a very good job clarifying this... unless I'm missing it. I've personally only seen the 3/4 ton trucks with the master that buldges around the rear chamber.
I'm curious since I have all the parts to convert my 69 C20, but haven't tackled it yet.
Old 01-25-2013, 11:58 PM   #23
chipflyer
chipflyer's Avatar
Like the one in the link of livrats first photo, post #6. Shape of the master cylinder doesn't mean much anymore. Take a look at the link below from autozone, they show 3 different styles for a 71 K20. I personally bought a new master cylinder at advance several years back and we looked in 3 different boxes with the same part number and each box had 3 different styles in them. Kind of surprised me and the guy behind the counter.
autozone master cylinders
Old 01-26-2013, 12:14 AM   #24
chipflyer
chipflyer's Avatar
Just wanted to point out that starting at post #6 just about anything you might need to know about boosters, master cylinders, and even the brackets for 1/2 and 3/4 ton trucks can be found with pictures. I believe this same info is also in the FAQ section.
Hope this helps
Jeff
Old 01-26-2013, 01:20 AM   #25
FirstOwner69
I'm not trying to argue with you. Just trying to answer the OP's question regarding which MC line goes where and to clarify this for myself.
Your posts and Livrats' posts in the other thread seem to indicate that the lines from the MC would be front-to-front or rear-to-front depending on if the truck is a 1/2 or 3/4 ton and that the guidance I gave in post 20, where I stated the rear chamber (the larger) serves the front disc brakes, could be incorrect. I said this based on the fact that this discussion has been about a 3/4 ton 4WD truck. Livrat's 6th post seems to show this in the 1st picture. So, do you argee that the 3/4 ton should be front to rear regardless of the appearance of the 3/4 ton MC?
EDIT: I just looked at the Autozone link for 71 C20s. They show 4 MCs, but there appear to be 2 types. Two say for front discs (with the bulged rear chamber area). The other two say for front drums. Didn't know any 71s had front drums.
