11-27-2005, 02:02 PM | #1 |
Heater Box Question
I have removed the heater box cover while restoring my firewall, when re-installing is there a gasket inbetween the heater box and firewall??? All I found there before was dumb dumb, which I scrapped off with wirewheel.
If there is a gasket ...is it cork or rubber?
http://i30.photobucket.com/albums/c3...c/IM001769.jpg |
11-27-2005, 03:22 PM | #2 |
ureckmefixit2@cox.net
Re: Heater Box Question
Clean out the old stuff and replace it with strip calking you get from the paint store. You can us butle window sealer too, it comes or a roll. Make sure you use enough the fire wall is not flat. Matt
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
