06-09-2004, 08:20 PM | #1 |
user # 2756
installed ORD 0 rates
Can you tell? first pic of each side is before. Made room for some 35-14/16.5 Ground Hawgs on order.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm Last edited by JIMs70GMC; 06-10-2004 at 04:41 AM. Reason: correct spelling of "hogs" |
06-09-2004, 09:24 PM | #2 |
I can and it looks good. They are just 1" right? Is it legal to install them on the front, aren't they basically a block? Should have a real nice stance with those wide 35's under there. Definitely noticeable!
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
06-09-2004, 09:59 PM | #3 | |
06-10-2004, 04:44 AM | #4 |
user # 2756
Yep they bolt in. 1" of lift. Still have some front to rear rake. I'm thinking something was done with the rear springs by a PO. I could probably lower the rear another inch and be close to level. When I got the truck it set low in the back because of a flat bed. When I took the flat bed off the back end went up, a lot!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
06-10-2004, 08:35 AM | #5 |
The Blazer King
Looks like more than 1 inch. Looks good.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
06-10-2004, 04:53 PM | #6 |
I like how it looks. did they move your axles forward that much?
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
06-10-2004, 09:37 PM | #7 | |
Geared for Collision
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
06-10-2004, 10:18 PM | #8 |
user # 2756
Yep, I just got an inch of lift. Did not move the axle. Stoked about the ground hawgs. Tyres International has them on special $118 ea regular $192ea. That's for the 14-35/16.5 the 35s for 15" rims are also on special. With shipping it's right at $530 for 4 tires.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm Last edited by JIMs70GMC; 06-10-2004 at 10:21 PM. |
