Old 08-06-2004, 04:27 PM   #1
67-70c10
67-70c10's Avatar
Powdercoat Question
Can plastic pieces be powder coated? I thought it would be a great idea to powdercoat a few plastic trim pieces. Anyone know if this is possible?
Thanks!
Jim Smith
67-70c10 is offline   Reply With Quote
Old 08-06-2004, 04:56 PM   #2
Bobalouie
Fetzer Valve Technician
Bobalouie's Avatar
No, plastic cant be powder coated. Plastic is electrically inert for the most part, and cannot hold the charge needed to attract the powder. Plus the 400° F or so temps would be a bit much for some plastics.
1972 Chevy K10 SWB
Bobalouie is offline   Reply With Quote
Old 08-06-2004, 06:39 PM   #3
cdowns
cdowns's Avatar
no to powdercoating yes to chromeplating
Old 08-06-2004, 10:00 PM   #4
incoma
incoma's Avatar
cdowns - you peaked my curiousity. chrome plating plastic is a special process isn't it? I thought it was not like plating metal.
incoma is offline   Reply With Quote
Old 08-08-2004, 11:15 AM   #5
gregfull
gregfull's Avatar
incoma,
Yes it is a special process, it is done in a vacuum. Years ago I used to send gage clusters and a/c balls to a place in Michigan called American Plastic Chrome. The other day I spoke to Mitch @ BeCool Radiators, they have their electric fans chrome plated in Florida. I'm sure if you called Mitch @ BeCool he would give you a name and number.
Good Luck!
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 08-08-2004, 08:22 PM   #6
JimKshortstep4x4
Smile
We used to have a plastic plater in our plant. The plastic went through a "preplating" process where it was coated prior to going through the plating process. In the plating process, the parts were dipped in three baths of copper, then dipped in nickel baths, with final dips in the chrome tanks. It was a quite extensive process.
The plating that gregful described is still done in the plant. What he described is "Vacuum Metalizing". Parts are coated, placed in a vacuum chamber where they are charged with electricity. Strips of aluminum are placed on copper rods in the chamber which have the opposite charge as the parts. At an extremely low vacuum the aluminum vaporizes and since the particles are charged they are deposited onto the parts. The result looks very much like chrome.
Jim
Old 08-08-2004, 08:37 PM   #7
incoma
incoma's Avatar
Thanks for the input. I'd like to see this process. I've watched powder coating and various painting processes, but coating plastic sounds like a wicked process. Are there any places to have stuff "re-plated"? I've been buying re-coated parts, but it sure would be nice to have my own stuff re-plated/coated.
