Old 09-01-2004, 11:20 PM   #1
RShaips
uneven rear springs ?
I have new 4" drop springs in my 67 SWB, one side of the bed is 3/4" higher than the other. I would like the higher side to match the other. How can I fix this ? I was thinking about clamping a couple of coils together to lower it. Anybody done this? I have seen spacers for raising them but have never seen clamps for doing this. Thanks for the help
RShaips is offline   Reply With Quote
Old 09-01-2004, 11:23 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
like a small ubolt with a bar across and nutz to tighten it down? thats what i have pictured
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-01-2004, 11:26 PM   #3
RShaips
Thats what I'm thinking also, has to be the springs making it uneven, nothing else there.
Old 09-02-2004, 12:21 AM   #4
WB72
Before and After
WB72's Avatar
Be sure to check the frame Height, I had the same problem, and it turned out to be the crossmembers of the box were our of whack, I ended up changing those to correct the Droop in the one side.
Good luck.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 09-02-2004, 09:08 AM   #5
RShaips
I'll do that, How was your crossmember out of whack ?
