Old 09-25-2004, 07:07 PM   #1
matt_field
matt_field's Avatar
why is my speedo cable leaking from the transfer case?
on my 67 4x4 chevy truck. i put in a np205 transfercase and ever since i did it it has been leaking out of the speedometer cable greese fitting thing. my speedo cable also bounces around a lot. any way i can fix this easy? whats wrong with it? thanks i hope someone can help
matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 09-25-2004, 10:19 PM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
This link should take care of your leak: http://www.norcalbigdawgs.net/Gallery/album49
The speedometer bouncing sounds like it could be a bad cable. Measure the length of yours, make note of the ends (both on the T-case and on the speedo), and order a new one at GM when you order the part above.
badpeanut is offline   Reply With Quote
Old 09-25-2004, 10:56 PM   #3
matt_field
matt_field's Avatar
oh wow, thanks a ton!! i really appreciate it
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 09-25-2004, 11:43 PM   #4
badpeanut
badpeanut's Avatar
You're welcome. I was just looking at this site last night because my NP205 is leaking here, too--I'm going to give this part a try myself.
Old 09-25-2004, 11:51 PM   #5
chevytruckfan
chevytruckfan's Avatar
There is a rubber O ring in the housing between the cable and the case housing. Pull this housing out and check the O ring.
chevytruckfan is offline   Reply With Quote
