Old 09-26-2004, 01:22 AM   #1
Peregrine
Peregrine's Avatar
cab mounts
My cab mounts are getting kinda rotted for some reason. Is there a way to replace them without taking the cab off? Like loosening one side, jacking the cab up a little, slide them out and put the new ones in?
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 09-26-2004, 01:27 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Yep you can do one side at a time just like you said.. I t would help if the carpet was easy to get up so that you can access the bolt's....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-26-2004, 02:07 AM   #3
Gee_Emm
When jacking carefully watch the clearances between the doors and the front fenders, make sure they don't touch, also put your ebrake on as the shifting of the cab could knock the truck out of gear.
Gee_Emm is offline   Reply With Quote
Old 09-26-2004, 02:32 AM   #4
Jason71k10
ready for reassembly
Jason71k10's Avatar
yup, make sure you have the wheels blocked, just in case. I found out the hard way that lifting the cab can move the linkage.......i've never jumped into a moving vehicle so fast in my life!!
stock 71 4x4
2003 Jeep Liberty, rocky mountain edition
I'm obsessed, and wouldn't have it any other way!
Jason71k10 is offline   Reply With Quote
Old 09-26-2004, 04:35 AM   #5
avejoe
Custer had a plan too.
avejoe's Avatar
Yeah, I can vouch that jacking the cab up knocks the tranny out of park. I moved pretty quick too when I let the jack down.
I just replaced the mounts and it was an easy task. Don't forget to loosen the radiator mounts up too.
avejoe is offline   Reply With Quote
