Old 10-17-2004, 11:45 PM   #1
68327stepside
Front shock relocation
I picked up a set of front shock relocators this weekend at Pomona swap meet. I was wondering if anyone has a picture or advice on installing them. These are brand new from Brothers, the guy had sold his truck and didnt need them. Thank for the help.
USMC "Pray for peace, train for war"
(The Beast) 68SWB Stepside Original 325hp/327 3:73 Posi Lowered 3.5/4.5
68327stepside is offline   Reply With Quote
Old 10-18-2004, 06:50 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Why would you relocate your front shocks?
Old 10-18-2004, 07:43 AM   #3
SCOTI
SCOTI's Avatar
To regain shock travel lost from dropped springs.
68327, try looking through Brothers website for installation instructions or just give them a call & tell them you lost your instructions & would like another set. They should just require a couple of holes drilled on the top/side of the frame in the same area of the current shock stud.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-18-2004, 08:05 AM   #4
Joe67
67 is sold
First time I have heard of this?
Here is the info on the brothers website
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-18-2004, 11:13 AM   #5
68327stepside
Thanks SCOTI, I have been waiting for a reply from brothers. Hopefully they get back to me today. Tx firefighter, for proper operation the front shocks should be kept at an angle of 15 degrees or less. It is the same with the rear. I have the rear done already and believe me it really smoothes the ride out. Thanks to all for the help.
Old 10-18-2004, 11:36 AM   #6
ChevyCruizer
17's too small
ChevyCruizer's Avatar
the kit relocates the shock to a more vertical position. if you are only running spindels you do not need this kit. the shocks mount to the lower control arm so i spindel will not affect the orientation of the shock. when you bag the front and want to run low is when the shock becomes a problem. a bagged truck positions the shock to a more horivontal position. the shock lays down the more you lay the truck out. when the shock lays down you loose the mechanical advantage. these kits move the mounting location of the shock and you regain your mechanical advantage. should give a better ride.
i did not get my front relocator kit on yet.
but, i used a similar kit on the rear of my bagged 68. looking at it now, there was a huge differance. i do not know about the ride quality. i have not really driven the truck enough yet. i can tell you that i was able to drop the truck almost an inch more after the shock relocation. before my shock was bottoming out sooner inside itself, now it drops more. i have other issues. my ECE super track bar hits on my frame before my axle even comes close to my bump stops.
i attached 4 photos. they will prob be out of order
the 1st shows my ECE bar and my clearance problems. they designed their kit to work with a static (springs) 5 or 6 inch drop. i ran air and now i have a problem.
2nd shows the rear shocks with the relocator kit. the truck is laid out right now. when it is at ride height they are even more vertical. i wish i had a before photo. they were really angled.
3rd shows my front crossmenber laid out. again if you are only running spindels and 2 inch springs you will not need this shock relocator kit. your crossmember will be no where near this height. you can most likely fit a beer can under the front crossmember.
last one is a side shot of my truck
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 10-18-2004, 12:44 PM   #7
Joe67
67 is sold
I just called Dave at ECE and they only recommend relocating the front shocks on a bagged application. It isn't required on a spindle and minor spring drop up front.
I did relocate my rear shocks with the 6" drop.
Old 10-18-2004, 01:47 PM   #8
Tx Firefighter
That explains why I have never seen it before. I'm an old school suspension dropper.
Old 10-18-2004, 05:54 PM   #9
SCOTI
SCOTI's Avatar
I relocate mine only if there's not enough travel in the stock mounting location. My 68's are in the stock location; my 74's required relocating to get optimum travel (the shock is centered in its stroke @ ride height). Neither of mine are bagged but w/o relocating the shocks on the 74 they would've only had 1" of travel before bottoming out. Both trucks utilize off the shelf direct replacement shocks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-18-2004, 08:03 PM   #10
dylan1970
dylan1970's Avatar
ChevyCruizer... Are you still running on your trailing arms? I am looking into getting an air ride kit for my truck to and I am going to do a C-notch and use 2" lowering blocks as well. Do you have anymore pics of the installation of your air ride kit and a list of all I will need to do this. I also just ordered a transmission crossmember from ECE so this way I can keep running with a 3" exaust. Any help would be great!
dylan1970 is offline   Reply With Quote
Old 10-18-2004, 10:10 PM   #11
68327stepside
Thanks to all for the help! I got them installed today along with my disc brakes and complete rebuild on the front suspension. I have finally finished all my handling issue. Now on to the body. Rust Sucks
Old 10-18-2004, 10:35 PM   #12
ChevyCruizer
17's too small
i did not have my camera during the install. i looked through my files and included a good side shot. i can take more is there is something specific you want to see
yes i still have the stock trailing arms. when i did the rear end i pulled them out and replaced the 35 year old rubber bushing with polyurethene ones. the install was really easy. i do not have a plasma cutter yet, so i used a cut off wheel. i went through a disc on eash side. cut small and if you need to go back later and make it a little bigger. that way you are leaving as much metal as you can. with the inward curve of the rear frame it was a little difficult to suck the notch into place. i ended up using 4 six inch C clamps to suck it into place and then i drilled the holes. you may want to run a thick weld along the upper edge when you are done (if you do not plan to step notch it later) that way it will have a nice finished look, but then again who is gonna see the top when the bed is on.
an air hammer with a new chisel will come in quite handy for the frame rivets that you need to remove.
overall it is a very nice kit and an easy install. i am a little bumbed about my track bar problem. air lift makes a panhard bar that mounts lower, i wish i went with that one 20 20 hind sight see picture
i have not got my tranny member on yet. i still have the stock 6 cylinder for now.
i was looking at ECE's frame slayer cross member. the one that the trailing arms come off of, but i want to get some wheels first. so i can see how much lower i really want to go.
Old 10-18-2004, 10:40 PM   #13
ChevyCruizer
17's too small
the kit should have a nice template to show you where to cut.
the air bag mounts exactly where you stock spring was. no drilling required.
Old 10-18-2004, 10:45 PM   #14
ChevyCruizer
17's too small
template
Old 10-19-2004, 01:13 PM   #15
XXL
Señor Member
XXL's Avatar
I let them know about the interference problem a little over 5 years ago when I installed mine, and offered to provide them with dimensions on how to mod their kit. They blew me off.
XXL is offline   Reply With Quote
Old 10-19-2004, 04:09 PM   #16
paintpyro
paintpyro's Avatar
I have a set of front relocators. I got them from Bill Turner, exactly the same. I got mine because the top studs were busted, and the genius previous owner thought he was a fabricating god with oxy acetylene. My problem is, once I installed my 3 inch drop springs, the 3 inch drop shocks didn't fit. I had to get 2 inch drop shocks to get enough travel to the top of the frame rail.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 10-25-2004, 08:02 PM   #17
turmoline
paintpyro, you were able to mount the relocator to the top of the frame rail? I was going to buy a set, called brothers they told me it didn't mount on the top of the frame rail and no length was gained by using the bracket just an angle change. Thanks for shedding some light for me. How much length did you gain by using the relocator and what is the length of the shock @ ride height? Does the shock interfere with the inner fender? Do you have any pics. Thanks in advance.
turmoline is offline   Reply With Quote
Old 10-28-2004, 01:21 AM   #18
68327stepside
Turmoline; That is wierd, Brothers are the ones who told me to mount them to the top of the frame, worked out just fine. It is true you do not gain any length just an angle change. Take it easy.
Old 10-28-2004, 01:34 PM   #19
Slammed67
Progress = 0%
Slammed67's Avatar
Regarding the panhard bar interference with the bolt-in c-notch......
You could just fabricate a new passenger side mount like I did. I simply cut off part of the ECE bracket and welded it to the inside of the trailing arm. You could easily make a new bracket. Jut make sure your bar has enough length to reach the bracket once it's relocated. Mine reaches, but it is adjusted almost all the way out. I would have made the bracket stick out farther from the trialing arm if I had to do it again.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 10-28-2004, 09:27 PM   #20
turmoline
68327 stepside, thanks for the reply. yah usually most of the vendors that I've dealt with have no clue. most of the time I just order. If its not right send it back or re-engineer to fit my application. Just like the panhard bar bracket that slammed is talking about. I made a bracket similar to the vendors but flipped it.
Old 10-29-2004, 12:50 PM   #21
Frank_Zeller
Frank_Zeller's Avatar
Did the front Tunner relocator. Much better. 2 inch ECE springs with 2.5 drop spindals, stock length shock.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 10-29-2004, 03:54 PM   #22
smbrouss70
smbrouss70's Avatar
Frank,
I can't see the pictures even after I log in.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-29-2004, 04:18 PM   #23
Frank_Zeller
Think I got it right this time :0) The setup looks better than in the picture. The top frame rail flexes a little. Someday I will box the frame at that location. I had to remove the Z bar frame mount to make room for the one on the drivers side. So they might not work on standard trans equipped trucks. I had to cut the inner fender well as you can see in the picture.
Austin-Texas
Old 10-29-2004, 05:59 PM   #24
smbrouss70
smbrouss70's Avatar
Still just a red "x".
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 10-30-2004, 07:50 PM   #25
Frank_Zeller
PM and I will email pic
Austin-Texas
