10-21-2004, 12:48 PM | #1 |
Leaf spring swap
I am swapping out my old multi leaf spring with a new mono leaf spring setup from Performance online. I am putting the new mono springs in exactly the same place as my old multi. My question is; are the mono leaf springs installed the same way as a multi leaf? The reason that I ask is the kit that I was supplied with had U bolts with a squared off end to them. Does this mean that the U bolts are put in a different orientation? Here is a picture of the old setup I had before I tore down the truck.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi 1997 C2500 Ext Cab 5.7 Liter 1955 3/4 ton 1st series w/ 235 straight six Sold it |
10-21-2004, 11:27 PM | #2 |
i'm having a hard time picturing the new ubolts your talking about but i would like to help. pictures of the parts from the kit would be very helpfull.
ondrew |
10-22-2004, 10:06 AM | #3 |
Here is a similar picture of the kit that I bought. I was trying to figure out why the bolts are squared off; the only thing that I can think of is the U bolts go upside down and are placed over the spring instead of the axle. This orientation seems to be dangerous, but then again I have never put in a mono spring setup before. I found that the little bolts are for going into the saddle area (used as a stud in the center of the mono leaf spring)
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi 1997 C2500 Ext Cab 5.7 Liter 1955 3/4 ton 1st series w/ 235 straight six Sold it Last edited by Razor454; 10-22-2004 at 12:55 PM. |
10-24-2004, 12:55 PM | #4 |
OK i went out and looked at my 58. It has the multi leaf still,but the ubolts are square with the tread part down. I put monos on the front and they are square also. The bolt ends go down on them also. Hope this helps. johnj
you laugh at me cause i'm different ; i laugh at you cause you're the same |
