Old 01-05-2005, 02:09 AM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Sealing driprails
What do I need to use?I have rain seeping in the top of the windshield channel.I assume it's the driprails.Anyway,what is best to use to seal them back?
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 01-05-2005, 02:11 AM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
body shops use a product called seam sealer. i am sure you could find something on the 3M websight. make sure that you scrape all the old stuff out and prep it good so the new stuff can stick. and if all else fails use vulkum
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 01-05-2005, 02:41 AM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
There are two types one-part (stays flexible for a long time like the OEM stuff) and two-part (more expensive, epoxy type that takes a special applicator but is smooth and hard as a rock). The mess is getting the old stuff out and doing the seal job properly. This will require you to repaint the top of your cab and the drip rails. To do the job right you will have to take all of the old material out and clean the drip rail down to the bare metal. You can soften the old material with a propane torch and dig it out with a screw driver then use a high speed wire wheel or paint stipped to get the rest out. It is pain but it really should be done right to prevent further leaks and rust.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-05-2005, 03:56 AM   #4
Brainchild
Brainchild's Avatar
Paint isn't a problem,haven't made it that far yet
I'm gonna tackle this little project soon.It doesn't leak much,but any is too much.do the Autoparts stores carry this stuff?
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
