01-18-2005, 02:00 AM | #1 |
Custer had a plan too.
Options for Repairing Hacked Radio Hole
What is the best way to repair a hacked radio hole? I was hoping to replace the whole dash but after removing a donor dash today I don't see anyway to do this without removing the front glass.
Has anybody welded in a repair patch that came out looking good? Anybody have any pictures of a fix? Thanks!
72 K15 GMC (aka Big White) Performance Rockers, Cab Corners, and Floors Fossil Fuel Glutton Neighborhood Nuisance 98 BMW 540i for Speed (Sold ) 05 Subaru Outback for mileage |
01-18-2005, 02:10 AM | #2 |
I think there is a patch panel made.Don`t know who or where.Anybody?I have one that`s cut for a cheezy AM/FM/CD,doesn`t even work.I plan on buying a quality CD player.That`s how I`ll fix mine.I`d never cut one,but,if it already is...Good tunes ain`t bad.
01-18-2005, 04:07 AM | #3 |
Saving 1 truck at a time!
I welded a patch into mine without any problems. Just like welding a patch panel any other place on the truck. I will try to get some pics.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
01-18-2005, 04:52 AM | #4 |
You could always cut the dash under where the dash pad goes, that way no matter how bad your welding looks, it will be covered up.
01-18-2005, 08:16 AM | #5 |
Been there, done that.
The dash metal is rather thin, becareful. |
01-18-2005, 08:34 AM | #6 |
67-72 Addict!
On my dads truck he cut the center section out of another truck with a cordless sawzall and welded it in with no problems. I'll post pics soon.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-18-2005, 11:22 AM | #7 |
How bout using a radio delete panel and spot welding from the backside? Then cut the panel for whatever radio you want.
01-18-2005, 12:30 PM | #8 |
I cut an aluminum panel to cover mine up. It covers the original radio holes and where the ashtray was. Hated that damn ashtray anyway. I bolted it to the dash with some allen button heads bolts. Not show quality but it looked alright I guess. Trouble is now it's been "remodeled" a couple of times for different radio combinations and I need to build another one!
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-18-2005, 01:29 PM | #9 |
IF YOU CUT VERTICALLY THRU THE GLOVE BOX HOLE, & THRU THE INSTRUMENT CLUSTER HOLE. THEN HORIZONTALLY UNDER THE DASH PAD, ALL YOUR WELDS WILL BE PRETTY MUCH COVERED UP, REQUIRING VERY LITTLE BODY WORK. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
01-18-2005, 02:25 PM | #10 |
I'm going for the stock look so if it looks like I put in a patch I'm not gaining anything.
I've tried my hand at welding and you will not be seeing me on the Discovery or Speed Channel anytime soon. I think the best bet is to cut the middle out and use the dash and glovebox opening to hide most of the welds. The problem is welding the support channel that runs under the bottom of the dash well enough to keep the structural integrity of the dash.
10-22-2015, 08:41 PM | #11 |
Re: Options for Repairing Hacked Radio Hole
I recently purchased this patch panel because the PO hacked the dash for a newer radio install. Surprisingly the original speaker was still in the dash. I got a original radio on ebay and am planning on installing it soon.
Patch panel: http://www.motorcityk5.com/dashbezel...kup-1-1-1.aspx |
10-22-2015, 09:20 PM | #12 |
Classic sells the same piece and they often run 15 or 20% off. But like you mentioned... lots of welding.
http://www.classicindustries.com/pro...ts/t71098.html
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
10-22-2015, 09:23 PM | #13 |
You will have to decide if it looks good to you or not, but there's NO bondo or filler on my dash, just a piece of 18 ga sheet tigged into a new hole that removed both radio and ash tray. There are purists here that hate this look because i didn't use the ashtray and radio delete panels but it sure did fix the hack job the PO did!
10-22-2015, 09:33 PM | #14 | |
The Older Generation
Thing is it looks good with the theme of your truck.... LockDoc
10-22-2015, 09:34 PM | #15 | |
10-23-2015, 11:04 AM | #16 |
I cut my dash under the dash pad, a good fix
