Old 01-26-2005, 08:17 PM   #1
ozrulzk5
What can I do next ????
85 k5 gearbox question
Just replaced the gear box on my 85 k5 (4x4) and I noticed that the bolts going thru the frame have spacers on them. Seems to me like that would eat a hole the same size thru the frame before the bolt head hits the frame. My question is would it be wise to replace the bolts with shorter ones with washers to have a larger contact area or is this so the bolts will break if the gearbox gets into a bad strain without damaging the frame area????? any light on this area would great thanks
ozrulzk5 is offline   Reply With Quote
Old 01-26-2005, 08:47 PM   #2
85 K5
I've read the spacers keep the bolts tight. I you are concerned about the frame (as I am) you have reason to. Here's what I did.
http://www.offroaddesign.com/catalog/steeringkit.htm
The bolt on steering brace goes on easily and I can feel a difference.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock
http://www.oplnk.net/~spirit/K5front.jpg
85 K5 is offline   Reply With Quote
Old 01-26-2005, 09:00 PM   #3
1FaastC10
1FaastC10's Avatar
that's great if you are in fact talking about the steering gear. if not, what "gear box" did you replace?
1FaastC10 is offline   Reply With Quote
Old 01-26-2005, 10:46 PM   #4
ozrulzk5
Steering gear
