Old 02-11-2005, 11:42 PM   #1
chevykevy
chevykevy's Avatar
Help; Headers for 4X4 with clutch linkage
I want to install headers on my 1969 4 wheel drive manual transmission truck. The clutch linkage goes from the frame to a ball mounted on the engine block just below the dip stick. I think the truck came with rams horn exhaust manifolds so they exit below the center two exhaust ports. I need headers that will allow me to run the Z-bar across from the frame to the engine. Any info or part numbers would be helpful. Pictures would be cool too. Thanks
chevykevy is offline   Reply With Quote
Old 02-12-2005, 03:23 AM   #2
Jeremy_5
Truck addict
Jeremy_5's Avatar
Is it a big block or small block? I personally haven't tried these but was told for a Big block these will fit. They are hooker headers part # hok-2463hkr.
You can pm Nick's683/4 he is running these headers and can probably give you more info or pictures.
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 02-12-2005, 04:20 AM   #3
500HP/SB
please don't break
500HP/SB's Avatar
I Have doug thorley headers on my small block. i beleive they are listed as small block 4x4. my truck is manual. my truck came with these so i dont know the details, i will try to take pictures tomorrow
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
Old 02-12-2005, 10:00 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I beleive the tri-y's are the only model specific brand for manual 4wds of this era. Other brands require modification to the linkeage. I went with the 2.5" centerdump ramhorn(vide the stock 2") that came on the 63/64 vettes w/ a 327.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-13-2005, 12:46 AM   #5
Devil'S Ride
Im runnin Hooker SUper comps built fer a 69 chevelle on my truck. I had to heat em an bend em just a lil to make them fit the body lines, but other than that they clear all my linkage just fine.
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 02-15-2005, 12:21 PM   #6
turkeyguide
I had headers on a '72 4x4, but I don't know what kind they were. They were already on the truck when I bought it. They had used a hammer to make them fit. Just like the muffler commercial on tv. "We can make it fit". Don't try this at home.
turkeyguide is offline   Reply With Quote
Old 02-15-2005, 12:24 PM   #7
poff
I have Hedmann Elites on my '70 K-20 with a stick. I order the headers for a manual transmission and I still had to dent them to clear the Z-bar. They are very nice headers though.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 02-16-2005, 01:57 AM   #8
Nick's683/4
Yeah like Jeremy said i got a 454 with headers and a 4 speed. I had to cut the end of the linkeage off. The part to make it move more??? and i had to put a small starter on it. The stock one was to close and wouldn't move after the truck got hot.
Nick
70 1 ton with a 454 and a 4 speed and a np205
Nick's683/4 is offline   Reply With Quote
