Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-21-2005, 05:25 PM   #1
billsbowtie
billsbowtie's Avatar
68 9 inch rear end f/s
it came out of a 1968 mustang i think the gear is 323 or 325 it is not posi. it was in my 67 chevy truck when i got it $275.00 no shipping
billsbowtie is offline   Reply With Quote
Old 02-21-2005, 07:40 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
can we see the other side?? Also what is the bolt pattern and the length end to end from axle to axle?? Thanks
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 02-21-2005, 11:49 PM   #3
billsbowtie
will try to get you a pic. tomarrow
Old 02-21-2005, 11:53 PM   #4
billsbowtie
It Is The 68 Mustang Bolt Pattern
Old 02-22-2005, 12:10 AM   #5
phantom dually
Hell I dont know what that is FOR*
Old 02-24-2005, 04:50 AM   #6
billsbowtie
here is the other side
Old 02-24-2005, 05:03 AM   #7
phantom dually
PM sent
Old 02-26-2005, 08:57 AM   #8
DelRay
DelRay's Avatar
Does it have an N cast into the center section?If it does its worth more than $275.
Steve
DelRay is offline   Reply With Quote
Old 02-26-2005, 11:45 PM   #9
bigarmzz
bigarmzz's Avatar
this might be a stupid question...but would this rear fit a 81-87 2wd?
-bigarmzz-
bigarmzz is offline   Reply With Quote
Old 02-27-2005, 12:25 AM   #10
f.monroe
f.monroe's Avatar
Looking at the rear in the pics it looks like it has only one rib cast into the carrier .All N (nodular ) centersections had two ribs and the N was inside the ribs. Frank
f.monroe is offline   Reply With Quote
Old 02-27-2005, 12:29 AM   #11
phantom dually
I assume one is stronger than the other??
Old 02-27-2005, 12:40 AM   #12
f.monroe
f.monroe's Avatar
Yes Sir .The N cases are the stronger cases that Ford used in high performance applications .They are stronger but a friend of mine had a 11-12 second (slicks vs. street tires)1972 Ford truck that used a single rib center with no problems .I am not a Ford fan but that truck was a blast on the STREET. Ran a 12.09 at Houston Raceway Park on 29-12.50-15 Sportsman Pro's ,pump gas ,all motor no nitrous, with exhaust. That was in 1991. Slicks made it faster but it started breaking things. Frank
