Old 03-25-2005, 12:12 AM   #1
pjmoreland
pjmoreland's Avatar
Need A Picture of Stock Tach Harness Firewall Hole Needed
Does anybody have a picture they could post that shows where the tachometer wiring harness passes through the firewall on a truck originally outfitted with a tach? Thanks.
pjmoreland is online now   Reply With Quote
Old 03-25-2005, 12:54 AM   #2
skokie
skokie's Avatar
I dont have one but I would like to see the stock hole so I can run the wires correctly. TTT for ya..
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 03-25-2005, 07:52 AM   #3
JimKshortstep4x4
Talking
Here is a picture of a 72 with factory tach. The wire hole is beween the fuse panel and the e-brake cable openings.
I am not sure if all years were the same. I have a 70 to look at and if it is different I will post a pic of it.
Jim
Old 03-25-2005, 01:07 PM   #4
pjmoreland
pjmoreland's Avatar
Awesome. That's exactly what I was looking for. My truck's a '72, so that's perfect. I don't suppose you know what the diameter is of that hole? Thanks!
Old 03-25-2005, 08:57 PM   #5
JimKshortstep4x4
Talking
The hole is 3/4" in diameter. If you notice there are (3) dimples in the firewall plus the hole. You should have a dimple in the location where the hole is in the pic.
Skokie,
The 70 is different and I am not sure which location the tach wire hole was in
since the bottom two dimple locations on the 70 has holes, (one was tach, the other was the kickdown wire. To be safe, someone with a 68 should let you know where the tach wire location is.
Jim
