05-30-2005, 07:46 AM | #1 |
springs or body lift
any advice on what is the best way to go,6"spring lift & 2"body lift,or 8" spring lift?will be used offroad as well as on road,towing boat,etc.
05-30-2005, 07:54 PM | #2 |
Uncle H. is this cartoon
Either are probably good. A 6" susp. lift and 2" body lift will give you a lower center of gravity than a full 8" susp. lift. It's also easier (and cheaper) to get more axle articulation with less suspension lift, typically. On the other hand for most offroading, 8" suspension lift would probably be the ultimate...
05-31-2005, 04:31 AM | #3 |
thanks for that uncle h.ive got to talk to an automotive engineer and see what i can do.need to get engineers report to make vehicle street legal over once you go higher than what the "dot"(department of transport)believes to be safe(1/3 higher than a standard vehicle,measured between bumpstops,they must be standard bumpstops as well)i'd rather go for spring lift rather than body lift,saves having to alter bumper bar mounts etc.
05-31-2005, 07:20 AM | #4 |
For what tire size do you need 8 inches of lift on, what?, a 67-72 K20?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
05-31-2005, 07:44 AM | #5 |
yeah sorry about that,its a 79 k20,id like to run 35"s or 36"s
05-31-2005, 11:55 AM | #6 |
user # 2756
I'm running 35s with 4" and 5" on my trucks, the tires do rub on my GMC but backspacing could help with that. Should only need 6" for 35/36s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
06-01-2005, 05:28 AM | #7 | |
06-08-2005, 08:20 PM | #8 |
i use to have a 1979 scottdale it had a 6" spring in the front and 4" blocks in the back with an add a leaf so it would sit level.i was running 35" x12.50 groundhawg tires on it.but if i was to do it again i would use 6" springs all the way around for better traction and my state does not allow blocks any more either.
06-09-2005, 04:09 AM | #9 | |
06-09-2005, 12:38 PM | #10 | |
i used to run 35's on my 87 with only a 4" lift.....tires never rubbed, and it looked good too
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 06-09-2005 at 12:39 PM. |
06-10-2005, 03:42 AM | #11 |
beautiful truck,bigarmzz!
06-12-2005, 12:16 AM | #12 |
You will have no problem running 35's with a 6" lift.
