Old 07-05-2005, 11:21 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
3 spd Manual question
I have a stock 3 spd manual tranny (on the tree baby), what brand is it and does it have overdrive? I feel it kick in when I gun it at high speeds (once only, just to see if it would) but I think thought it was just the other 2 barrels. When I went looking for gaskets so I can change the fluid in it I found a few options on the Autoparts site, and dont know which one is mine.
Parts choices
Thanks again guys
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 07-05-2005, 11:31 AM   #2
Putter
More Cowbell....
Putter's Avatar
Manual?....but you are describing an automatic. Best bet is that if the truck is a normal 1/2 ton & came with a 350 engine, it is most likely a TH350 tranny.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 07-05-2005, 11:36 AM   #3
phlegm
phlegm's Avatar
Thx putter, but thats kind of my point. I did not think the 3spds had Overdrive, and I dont think that mine does, I just wasnt sure since on the advance site, the have a 3 spd overdrive listed.
"Saginaw (Including OD); 3 Speed; Manual Transmission"
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 07-05-2005, 11:49 AM   #4
Putter
More Cowbell....
Putter's Avatar
If you don't have a clutch, that is not you.
Old 07-05-2005, 11:51 AM   #5
phlegm
phlegm's Avatar
O I see. from my first post, stock 3 spd tranny, I have a 3 spd manual on the col. Not a 3 speed auto, I should have been more clear. I will edit to clarify.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 07-05-2005, 12:08 PM   #6
farside847
farside847's Avatar
Huh, so is there a 3sp manual with an overdrive? How does the overdrive engage?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-05-2005, 02:07 PM   #7
pjmoreland
pjmoreland's Avatar
I had a 3 speed manual with an overdrive in a 67 truck with a 250ci engine. There was a handle under the dash that said "OVERDRIVE" on it that I had to push in to put the overdrive unit into a freewheeling mode. There was also an electrical switch that I had to pull when the engine was rev'd up, and then I'd let off the gas, and as the RPM of the engine decreased, the overdrive unit would kick into gear. The overdrive unit was mounted on the end of the transmission in place of the usual transmission tail housing. It had a cable and a wire coming out of it. You should be able to stick your head under your truck and see if you have one there.
pjmoreland is offline   Reply With Quote
