Old 07-10-2005, 04:48 PM   #1
briarpatch
briarpatch's Avatar
What brand of paint on manifold?
What brand of paint works well on intake/exhaust manifolds? Something readily available at most auto parts stores is desirable...
'67 C/10, '04 Tahoe
briarpatch is offline   Reply With Quote
Old 07-10-2005, 05:24 PM   #2
Gray Ghost
Gray Ghost's Avatar
On intakes I use Duplicolor Chevy Orange (#200), on exhausts I use 1500* BBQ paint but it never stays on long.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 07-10-2005, 06:17 PM   #3
1STtimePRo'71
1STtimePRo'71's Avatar
Not to hijack or anything but would you need to use a high temp paint on an intake? What kind of prep work needs to be done before painting?
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 07-10-2005, 06:40 PM   #4
Gray Ghost
Gray Ghost's Avatar
I just cleaned the intake with brake cleaner and a brush, then shot a light coat of color on it every 15 minutes for 2 hours. The paint I use is 500* engine color made for blocks and such. If you don't use high heat paint it will come off.
The first pic shows the C20 motor before installation with it's powdercoated manifold and self painted block and valve covers and the second is the El Camino motor with it's self painted intake. They are virtually identical in appearance. I doubt I'll powdercoat another one. The paint holds up fine.
Kelly
Old 07-10-2005, 07:22 PM   #5
briarpatch
briarpatch's Avatar
I soaked mine with the foamy engine cleaner, scrubbed with wire brush, then scoured with brush and warm soapy water. Looks like all the oily gunk is gone, so hope it's ok to paint...
'67 C/10, '04 Tahoe
Old 07-10-2005, 07:31 PM   #6
1STtimePRo'71
Cool. I'll find some engine paint then.
-Cory
1967 2 Wheel Chevy
Old 07-10-2005, 07:45 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
briarpatch,
I would hose it off with some brake clean too before shooting it.
Old 07-10-2005, 09:04 PM   #8
shifty
Questionable
shifty's Avatar
I used Eastwood header paint on my headers. I used Duplicolor engine paint on the bloack and heads.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-11-2005, 07:46 AM   #9
briarpatch
briarpatch's Avatar
Originally Posted by Longhorn Man
briarpatch,
Will do...thanks Longhorn Man.
I've got the day off thanks to Hurricane Dennis, so I'll be headed to the store for paint this morning.
'67 C/10, '04 Tahoe
Old 07-11-2005, 10:51 AM   #10
70c10
67-72 Addict!
70c10's Avatar
Make sure you cure it (heat it up) according to the can. VHT is specific about how to do it. I'm sure other brands are as well.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-11-2005, 06:19 PM   #11
Gray Ghost
Gray Ghost's Avatar
Duplicolor requires no curing other than starting the motor and letting it run a few minutes. I've never used VHT.
Kelly
Old 07-11-2005, 06:34 PM   #12
tomatocity
tomatocity's Avatar
agree with all of the other members. Here is the link to Summit if you can't find what you want, http://store.summitracing.com/defaul...=egnsearch.asp , they have a huge selection at reasonable prices.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
