Old 07-11-2005, 12:11 AM   #1
skokie
skokie's Avatar
HEI Timing
For you folks with a hei on your smallblocks. What do you have you idle timing set to?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-11-2005, 12:15 AM   #2
tomatocity
tomatocity's Avatar
What are you running in your SBC: cam, carb, intake, heads, etc
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-11-2005, 01:05 AM   #3
kwmech
I've got mine set at 6, 400 small block, 5.7 rods, crane 268 cam
Old 07-11-2005, 01:34 AM   #4
skokie
skokie's Avatar
Crate 350 260 hp. Stock. Carb is a qjet. Intake is a edelbrock 2101.
68 build thread
Old 07-11-2005, 05:38 AM   #5
JimKshortstep4x4
Talking
Settings would be the same for points distributors or HEI distributors for initial timing. We set our small blocks at 10-12 degrees BTDC with the engine idling and the vacuum advance disconnected.
Jim
Old 07-11-2005, 06:05 AM   #6
GMC AMI
GMC AMI's Avatar
8 degrees BTDC is a good starting point. From there you can bump it up as long as there is no spark knocking and it does not hold back on the starter when trying to start.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
