Old 09-06-2005, 11:21 PM   #1
69CST10
Tilt steering column
Can anyone tell me how to identify a truck tilt steering column from a van tilt column?
69CST10 is offline   Reply With Quote
Old 09-07-2005, 07:42 AM   #2
neonlarry
neonlarry's Avatar
The location of the N\S switch, check out this post:
http://67-72chevytrucks.com/vboard/s...threadid=63328
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-07-2005, 07:11 PM   #3
HeavyD
HeavyD's Avatar
Also the bottom splined shaft sticks out further on a van tilt vs. a truck tilt. The truck looks "stubby" while the van sticks out quite a bit. Van tilt might also have a rectangular wiring connector instead of the semi round horsehsoe style connector used by trucks.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 09-08-2005, 08:49 PM   #4
69CST10
The tilt column I have has the longer splined shaft & rectangular wire connector.
There is no neutral safety switch or a hole for it on the column.
Any ideas what this column is out of?
Old 09-08-2005, 09:23 PM   #5
70short/step
70short/step's Avatar
Is it an automatic column?? The manual trannys didnt have neutral safety switches.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
