Old 10-07-2005, 07:11 PM   #1
billybob750
Would this work?
On my 85' 2wd the front end sags about 2" lower than the rear, I want to level it but dropping the rear is not an option. Ive seen 2" lift springs on ebay for like $120. I was wondering if I could swap coils from a GM 3/4 or 1 ton pickup in the same year range? Will they fit and would they raise the truck much? Anyone got any collecing dust?
billybob750 is offline   Reply With Quote
Old 10-07-2005, 08:00 PM   #2
beaterC10
The 2" difference in height is about normal for a stock 2wd. Drop shackles in the rear would get you about 1" drop for less money and effort than lift springs in the front. I was in Lexington this week on business, like the pretty countyside.
beaterC10 is offline   Reply With Quote
Old 10-07-2005, 08:58 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I replaced my front springs with HD replacements from my local auto parts store. It raised my front end up so it was level with the back. I think they cost about $75, and all the local stores had them in stock. You can see pics here:
http://www.slonaker.net/gallery/disp...?album=2&pos=1
To bad i was planning to lower it, and didn't know the store sold me heavy duty springs.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-07-2005, 10:42 PM   #4
hotrodhomi
hotrodhomi's Avatar
just lower the rear
hotrodhomi is offline   Reply With Quote
Old 10-07-2005, 10:55 PM   #5
Prerunner1982
Prerunner1982's Avatar
i second the HD front coils, they levelled my truck out as well...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-09-2005, 08:40 PM   #6
billybob750
dont want to lower the rear since ive got an off road theme going. might have to look into those heay duty coils
Old 10-10-2005, 11:39 AM   #7
Prerunner1982
billybob, check out the link if you would like to pics of my truck... i have an "off road: theme myself..
Old 10-12-2005, 12:12 AM   #8
billybob750
so 73-87 hd coils?
Old 10-12-2005, 09:10 AM   #9
Slonaker
Slonaker's Avatar
Originally Posted by billybob750
so 73-87 hd coils?
Yes. The ones that leveled my truck were HD coils for a 73-87 truck with a smallblock. All of the local stores stocked them, but the standard springs that I wanted were special order. Hopefully things are the same way where you are, and you be able to just walk in and buy them.
Slonaker
Stock '01 Silverado
Old 10-12-2005, 01:44 PM   #10
billybob750
hurt your alignment any?
Old 10-12-2005, 03:12 PM   #11
Prerunner1982
you have to take your spindles off when you put the springs in, always a good idea to get it re-aligned..
Old 10-12-2005, 03:26 PM   #12
Slonaker
Slonaker's Avatar
My alignment shop was able to align the truck with the regular and the HD springs. There were no problems with uneven tire wear or anything else when the HD springs were in.
Slonaker
Stock '01 Silverado
