Old 11-25-2005, 05:41 PM   #1
squeekyM
Lowering a C20??
Hi Everyone,
Hope we all had a great thanksgiving. I was reading through a post and 71dragtruck and ratrod67 (spl?) both had posted pics of their long bed trucks. Needless to say, they both are solid looking trucks.
I have a 72 C20, and would like to achive this look, but am concerned with what it would take to drop a truck with 8 lug hubs and 3/4ton suspension. Anyone have any methods on how I could achive a 4/6 drop on a rear leaf 3/4ton setup? Thanks for all the info, take care.
- Jerry
squeekyM is offline   Reply With Quote
Old 11-25-2005, 08:00 PM   #2
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Re: Lowering a C20??
Welcome to the board. I too have a C-20 but mine is a 1970.
As lowering goes I lowered my c-20, I used 3in drop Spindels from GMC Pauls, Item number 1181582. They are for a 73-87 truck but they will fit if you change upper ball joints (maybe lowers) and outer tie rod ends. I replaced all ball joints and tie rods while I was at it. You also might have to do something with the steering stop because the spindels have a longer stop then the 67-72s have. I also plan on cutting one coil out for a 5in drop in the front.
For the back I used a flip kit. I bought perches from a local speed shop. I also c-notched it and boxed in the frame around the area.
I dont have any good pictures yet but Ill post some tomarrow.
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 11-25-2005, 08:53 PM   #3
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
I take it you haven't seen this baby yet...........
before pics....
And some after.....
I have followed the progress on this truck over the time and is a ver nice truck!!
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 11-26-2005, 12:46 AM   #4
squeekyM
Hi,
Thanks for the replies. The GMC looks sweet. So it sounds like spindles and a flip kit for the rear is the way to go. Any ideas on what would need to be done to switch to a 5 or 6 lug pattern. Thanks again for the help, looks good.
- Jerry
Old 11-26-2005, 09:17 AM   #5
So you have leaf rear,right?Cuz coils are the same to drop as 1/2t in rear.You need to decide if you want it to be a half or three quarter ton,first.If you don`t want the better brakes and wheel bearings of a 3/4t,then go out and buy a dropped spindle/disc brake conversion kit for pre-71s and change to a 12-bolt rear.There are lots of custom 8-lug wheels.So,I`d suggest staying with what you`ve got and just do a low 3/4t.More trick,IMHO.
Old 11-26-2005, 03:47 PM   #6
crazy longhorn
Fabricate till you "puke"
IMO, its cheaper to swap 1/2 ton pcs under,especially on the wheel selection, & the front suspension. here is the route I went.... http://community.webshots.com/user/hotrodhorn L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-26-2005, 04:17 PM   #7
jostrans68
Jostrans68
jostrans68's Avatar
look up member name cobalt he has been doing this also
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 11-28-2005, 03:48 PM   #8
WB72
Before and After
WB72's Avatar
I converted my C-20 to a half ton front and rear, then used lowering parts for a C-10 and 73 and newer front end parts. It was pretty cheap actually.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
