01-22-2006, 06:41 PM | #1 |
f150 mirrors
i know some of you guys are running these on your trucks. i been thinking about it as well,but concerened about the support from the small mounting area bending my door on a bouncy 3/4 ton short box 4x4 do they seem prety stable or do they viberate and shake around a bit i dont want every car that comes up behind me at night to look like he has flashing lights
common sense isn't so common anymore |
01-22-2006, 07:03 PM | #2 |
Re: f150 mirrors
There's an arm that extends into the door. I cut mine off and just mounted to the sheetmetal with a backing plate and they were pretty stable. If you wanted to take the time, you could find a way to use that arm to add support.
01-22-2006, 07:09 PM | #3 |
Re: f150 mirrors
i used a backing plate aswell, after trying to weld my own support arm to the existing one, and then finding out ford used an aluminum one so i didn't have any luck with that. i havent driven it yet so i can't tell you more than that.
01-22-2006, 07:19 PM | #4 |
Re: f150 mirrors
Can you guys put some pics up? Ive been lookin at options for new mirrors but can't recall if I've ever seen f150 mirrors on our trucks. Thanks.
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! |
01-22-2006, 11:55 PM | #5 |
Re: f150 mirrors
no problem
01-23-2006, 12:07 AM | #6 |
Re: f150 mirrors
heres my truck someone told me that they where aftermarket f-150 mirrors
http://67-72chevytrucks.com/vboard/s...=pics+promised
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-23-2006, 12:33 AM | #7 |
Re: f150 mirrors
Those are sweet! One more thing on my ever growing list of things to do....
01-23-2006, 01:54 AM | #8 |
Re: f150 mirrors
pics...
01-23-2006, 11:38 AM | #9 |
Re: f150 mirrors
where on these does the brace go, i think they look great as is are these break away mirrors?
01-23-2006, 12:01 PM | #10 |
Re: f150 mirrors
for mine instead of using the 2 screws to the door skin alone, i put a thick piece of steel behind the doorskin and ran the screws through that. it's like using a hidden washer. for the support arm, i cut if off.
01-23-2006, 11:28 PM | #11 |
Re: f150 mirrors
I haven't had any problems with mine either. I even run with trailer mirrors slipped over mine the odd time.
01-23-2006, 11:38 PM | #12 |
Re: f150 mirrors
hi i am glad to be a member of the board i have a 1969 chevy cst long bed fleetside
01-24-2006, 01:20 AM | #13 | |
Re: f150 mirrors
01-24-2006, 01:55 AM | #14 |
Re: f150 mirrors
that is the brace that goes inside the door?then if used you mount it to anywhere you can that it won't interfear with window mech.?
01-24-2006, 04:45 PM | #15 |
Re: f150 mirrors
Yep. It would be under the vent window.
01-24-2006, 07:50 PM | #16 |
Re: f150 mirrors
i'll have to try to salvage a oair of them i need to figure out what i'm gonna use for mirrors before i start body work on my doors so i know if i need to weld up current holes thanks guys
