Old 01-25-2006, 12:20 AM   #1
truckdude239
truckdude239's Avatar
need help
okay so i ended up buy a remanded 350 4bolt main from advance auto for 960 buxs the guy installing it will not install it unless i get a new flywheel he says that the flywheel on my 307 is different from the ones that go on the 350 and says that my 307 start will not start a 350 i think different. some please confirm that my parts will bolt up
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-25-2006, 01:03 AM   #2
sdkid
Re: need help
According to napaonline dot com, they take the same flywheel. I think most sm chev are the same. You'll need to find out what the specific problem is with the old one.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 01-25-2006, 01:06 AM   #3
truckdude239
Re: need help
all he says is it is a different style i the motor i ordered was for a 1971 c-10 with 350 4 barrel with 4 bolt main i was looking at advance auto and it also shows same flywheel and same starter guess i will show himt his in morning
David fuller
2000 Tahoe 5.3l 378
Old 01-25-2006, 06:58 AM   #4
dwaite72lnghrn
Re: need help
Are you sure you didn't get a 350 with a 1 piece rear seal? The crank flange is different on them. Other than that I thought they were the same.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 01-25-2006, 12:18 PM   #5
jsbgump
Gone Fishing
jsbgump's Avatar
Re: need help
As long as it is not a 1 piece rear main seal motor, the flywheel and starter will be the same.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-25-2006, 01:44 PM   #6
mrein3
mrein3's Avatar
Re: need help
In 1989 I rebuilt a 350 out of a mid-70's Monte and put it in place of my 1972 Chevelle's 307.
I was working at a shop back then so I had access to a hoist where I did all the work.
So I get EVERYTHING hooked up. I check everything twice as this was my first project like this solo.
I put the car down on the ground and hit the key -
All I heard whas the starter moter spinning freely.
Yep. The 307 flywheel was smaller in diameter that what I needed.
A trip to Midway Chev and $50 later I had that engine running with a brand new GM flywheel on the back of it.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-25-2006, 01:55 PM   #7
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Re: need help
If I understand things correctly, there are only 2 flexplates available for the small block chevy engine with 2 piece rear main seal:
A 153 tooth (12.75") and a 168 tooth (14"). The 400 small block motors have a unique counterweighted flexplate, and I am ignoring those for this.
I think the starter is different depending on which motor is used, and as long as both the starter and flexplate from your 307 are used on your 350, you should be good to go.
A quote from Sallee Chevrolet website: "The starter must be matched to the flywheel or flexplate diameter when installing the Premium ZZ383/425 engine. Small diameter flywheels are 12-3/4” and have 153 teeth. Large diameter flywheels are 14” and have 168 teeth. This difference in flywheel diameter requires two different starter housings. Starter noses used with 14” diameter flywheels have two offset bolt holes; starters used with 12-3/4” flywheels have bolt holes that are straight across from each other."
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 01-25-2006, 02:16 PM   #8
truckdude239
Re: need help
when i looked up the 71 c-10 with 350 it calls for the same flywheel as the 307 the 168 tooth flywheel i guess i will get him to try anyway
David fuller
2000 Tahoe 5.3l 378
