Old 04-07-2006, 08:14 AM   #1
trailzen
Question Two front shocks?
My 70 has two front shocks per side,was this the norm or something someone added later on.It doesn't look like a traditional dual shock setup as they are in slightly different locations and not side by side
trailzen is offline   Reply With Quote
Old 04-07-2006, 08:28 AM   #2
Huck
Huck's Avatar
Re: Two front shocks?
Never came from the plant that way. Typical for off-road applications. My had doubles from the previous owner. Rode a bit too hard for my taste so I went back to stock.
Huck is offline   Reply With Quote
Old 04-08-2006, 01:36 AM   #3
teamradrz1
teamradrz1's Avatar
I have duals on my Blazer and I agree it rides rough but I like the look of it. The 4X4 shop told me to drill a hole in the bottom of one shock on each side so you have the look with the softer ride. Not sure if I want to do that.
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 04-08-2006, 07:20 AM   #4
vtblazer
vtblazer's Avatar
Or you could get the right shocks for your application.
The shop is giving you the easy/cheap method by telling you to kill one of your shocks. Bad advice IMO.
Adding another shock to an existing one will produce a really harsh ride.
Buying shocks that are designed to run in pairs will ride pretty much ride as nice as a single.
(they will have much softer valve rates)
vtblazer is offline   Reply With Quote
Old 04-08-2006, 06:49 PM   #5
Medicanman71
Medicanman71's Avatar
^ VT said it
Medicanman71 is offline   Reply With Quote
Old 04-09-2006, 12:24 AM   #6
1976K5CHALET
1976K5CHALET's Avatar
Getting the correct shocks should cure the issue.
On our web site...blazerchalet.com...ok...aaron's web site he has a link to his brochure page. I believe there is a scan of a old peterson's mag from 79 when they took a bone stock 79 K5 into the desert and thrashed it...through out the thrashing they kept records of lap time...and shock temps...and they started adding parts as the test progressed...
The idea behind twin or multiple shocks is to combat shocks from fading under use...the two shocks are valved lighter...but add up to one normal shock...thus transfering the load from one shock to to shocks. Heat kills...
One way to test your own shocks is the same old way they have done it from years...drive it around a semi rough road so the piston in the shock cycles quit a bit and then record the temps at all 4 corners with a thermo gun...if its cold...its not working...
Personally i have to admit i like the triple shock set up that i believe rancho sold back in the day....just for the looks...lol.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 04-09-2006, 07:22 PM   #7
trailzen
I took some pics today which shock should be there?
Old 04-09-2006, 07:47 PM   #8
71jimmy
71jimmy's Avatar
The one on the right!
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-09-2006, 11:17 PM   #9
trailzen
Good I removed the right one ,whoever installed this did a fairly good job made a nice bracket for that second one,almost looked factory ,I love working on trucks that have had a dozen different owners with two dozen ideas each!!
Old 04-10-2006, 05:49 AM   #10
vtblazer
vtblazer's Avatar
Ride better now?
Bet it does.
Old 04-10-2006, 08:20 AM   #11
trailzen
I hope it rides better some other things need to be finished first to find out
