04-08-2006, 12:27 AM | #1 |
Still Green but learning
Dumb Climate Control Question
How do I cut it off. not on low heat not on low cool but OFF it wont cut OFF, Its always blowing air, why wont it cut off. Off OFf OFFFFFF!, lol..... any help will be appreciated I havent cut the air off in a year (since I bought it).
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
04-08-2006, 12:38 AM | #2 |
Re: Dumb Climate Control Question
Sounds like you gota bad switch if the fan is still running when off you could replace it. Or until then try to find and pull the fuse or pop the hood and disconnect the wire going to the fan motor.
04-08-2006, 01:06 AM | #3 |
maybe, but what exactly is Off, there is not an Off posistion that I know of.
04-08-2006, 08:02 AM | #4 |
blood type; Retumbo
moving the lever all the way to the left SHOULD turn the fan off and kind of stop the airflow. now if only there was a way to shut off the coolant flow from the inside without adding another control
04-08-2006, 10:47 PM | #5 |
similar problem. mine will go off (i think) but air still gently blows through depending on driving speed. is that the same problem?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
04-09-2006, 12:56 PM | #6 |
just unplug the darn fan switch plug from the back
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
04-09-2006, 01:27 PM | #7 | |
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
