Old 04-19-2002, 07:39 AM   #1
RodC
RodC's Avatar
Post Heater wont close off
I have a '71 c10. The heater don't want to shut off. When on the highway it gets pretty hot in the cab.
Is there a seal that needs replaced or should I just put a shutoff valve on the heater core?
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 04-19-2002, 07:43 AM   #2
tom hand
CCRider
tom hand's Avatar
Post
Napa sells a nice manual valve that fits in the heater hose. I have always used them because most factory valves with any age to them will not shut off 100%.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 04-19-2002, 02:58 PM   #3
JW
Post
There is a heater valve on the inner fender, passenger side. One of the water heater hose connects to this before continueing on to the heater core. This #$%@ thing is expensive for what you get, $30.00. This valve becomes corroted by water. I have to replace mine every two years.
72 Cheyenne Super, Fleetside, Shortbed,
Original Owner, Special Ordered
Northern Calif
350ci/340hp, Auto Trans, 3:70 Posi, Tow Package
Northern Calif
JW is offline   Reply With Quote
Old 04-19-2002, 07:58 PM   #4
RodC
RodC's Avatar
Post
I just checked my chasis manual, seems like only the models with ac have a shutoff for the core. I was hoping that there was a vent/damper not sealing properly.
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
Old 04-19-2002, 08:09 PM   #5
Desert Rat
Desert Rat's Avatar
Post
I had a truck that always pushed hot air out the vents,always stayed on blowing a little,my quick fix was unplug wire in summer,hook back when cold.Sounds like your flapper door might not be shutting all the way,maybe a cable adjustment?
Desert Rat is offline   Reply With Quote
Old 04-19-2002, 08:33 PM   #6
jvclark2001
Post
you can buy those heater valves in a hard type plastic and i have had on on my car now for about 7 yrs now....still looks the same and no problems since i replaced it...i just went to auto parts house and asked to see an asortment of heater valves and picked the one i liked...just my 2 cents.......jv
1972 swb, 400 sbc,
1978 malibu classic,305 balanced and bluprinted flowmasters,2 1/2 exhaust,pulleys,k/n 4" power filter,750 edelbrock carb,plus lots more......
1972 swb, 400 sbc,
RIENZI,MS ...just southeast of Memphis...
jvclark2001 is offline   Reply With Quote
Old 04-19-2002, 08:59 PM   #7
gearhead dave
Post
i just bypass the heater core in the summer, i'm too cheap i guess!! LOL
1976 Crew Cab Dually (under construction)
1972 Suburban
1955 Pro Street Chevy
1985 S-10 Blazer (daily driver)
V W Sandrail
Located in Horn Lake, MS that's just 4 miles south of Memphis TN
www.classictruckshop.com/clubs/earlyburbs/members/gallery2/223/display.htm
Former engine builder for Racing Head Service
Performance Engines in Memphis TN. over 1,600 plus engines built by little ole me!!
GOD BLESS THE BRAVEST OF THE BRAVE...THE NEW YORK CITY FIRE FIGHTERS!!
gearhead dave is offline   Reply With Quote
Old 04-19-2002, 10:35 PM   #8
BubbaGreen
Post
Well, make sure the cable that passes thru
that little plastic plug/cap from the inside
of the cab (under the glovebox area) is still
connected to the flapper door that is suppose
to seal the air off from the heater core.
If the truck has been parked under leaves and
crap...it gets in there and actually can keep
that door/flapper from closing all the way.
I just rebuilt my heater core box/assm and
was amazed by how much junk can get in there.
its really hard to clean out good without
taking the box off the truck. I really need
to get a digital camera...I would upload some
pics of it. I had all the inside metal pieces
powdercoated...and it looks super nice now.
Gonna have to wait at least another year to
add a/c..:-(
What started out as a simple motor change
has turned into a frame off full blown resto!
Goodluck.
If you do decide to by-pass the heater core
in the summer, be sure and run a garden hose
of water thru it....just to flush it out,
will extend the life of it!
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
