06-15-2006, 02:46 PM | #1 |
Where to find a 2 wire vehicle harness-to-HEI connector
Hello, I have looked at murrays, pepboys, autozone and do not find a 2 wire plug for the HEI I am putting into my BB.
I need the two wires so I can hook up the tach to it. According to all the conversion schematics I see, you need the two wire plug. Where can I buy a new one? Thanks
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
06-15-2006, 02:50 PM | #2 |
Re: Where to find a 2 wire vehicle harness-to-HEI connector
I'm pretty sure Summit has 'em. I could of sworn that I have on occasion seen them at local parts places. I know you want the plug, but seperate electrical female spade terminals work too. Good luck.
06-15-2006, 04:06 PM | #3 |
its all about the +6 inches
You can use a crimp on spaid terminal.
You could go to the junk yard and get one, if you get one off a pontiac or caddy, there'll be plenty extra becouse the dist being up front. (just get a power lead, nothing special about the tach wire) |
06-15-2006, 04:38 PM | #4 |
Google Performance Distributors. I know they have them.
06-15-2006, 10:18 PM | #5 |
Adam B
http://store.summitracing.com/partde...5&autoview=sku
P/N: SUM-G5210 $4.95 I bought one a while back, works quite well. Adam |
06-15-2006, 11:31 PM | #6 |
Have you tried a Chevy dealer? GM has a two-prong connector that MIGHT be what you're looking for, but I haven't seen a picture, and it costs $27.67. It's PN 12167658. Then there's the HEI single power lead, PN 8917052, for $3.25.
06-16-2006, 01:03 AM | #7 |
13lazers' blazers
a 3 wire alternator with the side by side connectors fits, i think. napa has them on the shelf. i recently pilliaged an old chevette for all kinds of oem wire goodies and vacuum lines. i even got an inline washer pump. i like to splice the factory connectors i get from old wire harness' when i need them. all the plugs are the same in most gm vehicles even the crappy ones.
1970 2wd blazer 1972 1ton blazer 4x4 in progress 1966 mustang coupe (modified) 1985 c20 suburban tow rig 1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat almost all exempt from california smog laws intentionally. |
04-22-2011, 12:32 AM | #8 |
http://www.summitracing.com/parts/ACC-170072/ i know its 10 years later but just in case
1971 LWB C10 - 5.3/350 1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet 1964 malibu ss - ls1/4l60 http://67-72chevytrucks.com/vboard/s...d.php?t=382403 |
04-22-2011, 12:51 AM | #9 |
I know Schucks/oriellys has them under the Accel name. People behind the counter didn't know what I was talking about but they were hidden mixed in with the plug wires. Brought it home to my dad and he was you paid 14 bucks for that?! Took it back and we just used a wire connector.
You're not old, it IS loud! 1970 CST-10 BB 400 |
04-22-2011, 01:34 AM | #10 |
Cheapest route is to use 2 different plugs. PICO makes them and you can find them on eBay or Amazon. These will work:http://cgi.ebay.com/ebaymotors/HEI-D...Q5fAccessories and you can add good quality wire and solder it. Along those lines a slick way to get full voltage to your HEI (which is important) is to use a relay and use the original wire to switch it on and run good wire from your horn relay or other good source.
Larry 1972 Chevy C20 Custom Camper 1968 Chevy Camaro RS 1980 GMC K5 Sierra Classic |
04-22-2011, 04:14 PM | #11 |
The OP hasn't even logged on since 7/08. |
04-22-2011, 05:32 PM | #12 |
^Haha didn't even realize it, just went with the flow.
